Need Help Finding Pushrods
Old Jun 5, 2016 | 12:13 AM
chiefsfootball's Avatar
chiefsfootball
Hi, I'm currently building a 410 stroker and I have been searching for pushrods but cannot seem to find the right ones. In trying to avoid custom ordering because I assume that gets expensive and takes a while. I'm hoping that someone here may know of a similar pushrod. To what I will describe.
I am using Crane hydraulic lifters, part number 99281-16 (which I believe take a 5/16 ball). Then the other end needs to be a 3/8 cup that go to Harland Sharp rollers. I'm having trouble finding this set up. Has anyone seen/used pushrods like this?? Also, the overall length is aprox. 9.375" and effective length is aprox. 9.215". Any help is appreciated. Like I said I have looked through different brands and can't seem to find pushrods quite like this. Hopefully I don't have to special order. Thanks!
Old Jun 29, 2016 | 01:51 PM
69pig-penf100's Avatar
69pig-penf100
I know this is a little late but....im not sure about the 5/16 ball but if you use 3/8 on both sides I used these from summit COMP Cams Magnum Pushrods 7530-16 they come with little oiling holes on the top and bottom but they are filled and I'm using them with my Harland sharps tight fit but pretty nice.
Old Jun 29, 2016 | 04:21 PM
chiefsfootball
Thanks for the reply. It turns out those lifters actually take the 3/8. I called crane and I guess I was wrong!
wagonerkl
26
Jul 25, 2011 10:03 PM
shephard199
Feb 6, 2010 09:16 PM
mmuenchow
May 28, 2009 07:55 PM
Redmanbob
Mar 7, 2008 07:18 PM
66f100352
26
May 15, 2006 11:59 PM
