Boost gauge hook up?
Old Sep 19, 2007 | 10:40 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I was going to post about the hot side tap Kris but still have not heard from you on any results. If I were to do that I might just go with the MAP tap and keep the gauge on the AIH port to see what is really going into the cylinders.
Old Sep 19, 2007 | 11:00 PM
sflem849's Avatar
sflem849
Has anyone done the _____ mod yet? Tapping the hot and cold side and putting a valve in line so you can switch from hot to cold side on your gauge? Who recommended that F250, Strokin? idk
Scott
Old Sep 20, 2007 | 04:49 AM
Izzy351's Avatar
Izzy351
Originally Posted by countrycar
I'm with Joe on this. The AIH delete/Boost tie in, is the way to go. I think it's only like 20 bucks or so. I just can't find it. I can't recall which vendor sells it or I'd link it too yah. Joe do you recall the vendor?? Country
Can't remember, but here are some "plain" ones:
http://www.dieselsite.com/index.asp?...PROD&ProdID=48
http://www.itpdiesel.com/store.php?c...on=show_detail
Joe
Old Sep 20, 2007 | 08:43 PM
FroggF350's Avatar
FroggF350
Guys I really do appreciate the help on this. My truck is all aprt now since my WW came in wednesday i started on it this evening and now all i have to do in re-install my turbo and put it all back together, i also got my EGT gauge and will also be installing it. Any preferances on the location of the tap for the pyro?
Old Sep 20, 2007 | 09:17 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
right above the oil filter there.
Old Sep 20, 2007 | 09:29 PM
Tenn01PSD350
I put mine in the up pipe. Pic in a minute. About 2 years ago, still doing just fine and easy tap. Blow it and just clamp the hole and try again.
Old Sep 20, 2007 | 09:35 PM
FroggF350's Avatar
FroggF350
the kit that i have has the hose clamp type probe would this make a differance in the location of the tap?
Old Sep 20, 2007 | 09:38 PM
PowerstrokeJunkie
Nope, in the picture Tenn01 posted, just drill your hole there, no tapping required. Be extra careful with that ceramic washer. Looking at it wrong will break it.
Old Sep 20, 2007 | 09:42 PM
Izzy351's Avatar
Izzy351
Nope, but you don't have to tap yours. Just drill & wrap the clamp around the up-pipe or manifold. The reason some of us drill the up-pipe is because the manifold has cracked on occasion. I just didn't want to be one of the "occasional" ones that it happened to. Here's what mine looks like:
It is easier to drill up from underneath, too. Some folks go in from the top, but it's a much easier job from the bottom. Just be sure to use a nice sharp bit and wear goggles...
Joe
Old Sep 20, 2007 | 09:50 PM
Tenn01PSD350
What Joe said. Up pipe is cheaper and easier to replace than the manifold. I would have simply clamped a botch, tach welded it and moved up the up pipe. Since you wouldn't be tapping, a crack incident chance is much reduced, however rare it is in the first place, but you never want to be one of the 1 percenters.
Old Sep 21, 2007 | 10:11 AM
stormyrider's Avatar
stormyrider
As long as you have the turbo off, the ideal area would be where you are reading the exhaust off of both manifolds, so I would drill and tap the housing at the turbo exhaust inlet as long as you have it off and it is accessable.
Old Sep 21, 2007 | 11:00 AM
FroggF350's Avatar
FroggF350
is thia what you did? i would like to see a photo
Old Sep 21, 2007 | 11:09 AM
  #28
FroggF350's Avatar
FroggF350
where are you talking about:Here:
or Here:
Old Sep 21, 2007 | 03:40 PM
  #29
bdrummonds's Avatar
bdrummonds
The second pic is the inlet, the first pic is the exit.
Old Sep 22, 2007 | 12:12 AM
  #30
FroggF350's Avatar
FroggF350
Joe
I ended up putting it here
sudsmcduff
Sep 29, 2015 02:36 PM
dgulledge
Nov 3, 2014 06:03 PM
new7.3owner
Jun 8, 2014 01:10 AM
greenstar
Apr 2, 2014 06:04 AM
Bigdoon1522
Mar 19, 2014 11:08 PM
