Boost gauge hook up?
Old Sep 19, 2007 | 05:18 PM
FroggF350's Avatar
FroggF350
Where do you hook up the boost gauge hose? I tried to use the waste gate line but it doesnt read anything. Help please!
Old Sep 19, 2007 | 05:23 PM
stormyrider's Avatar
stormyrider
gO To The web site http://www.dieselmanor.com and click on install sheets under resources.
They have color photo's with instructions on two options, drill & tap turbo outlet or splice into the boost sensor line which is very easy to reach and do.
Old Sep 19, 2007 | 05:32 PM
Izzy351's Avatar
Izzy351
You tie into the MAP sensor line or remove the AIH and install a plug with a connector tapped for the gauge line. Tee looks something like this. Mine was one size too large so it looks jacked up, but at least you see where it goes (tee in front of the I/C boot). The "Bypass Valve" is the valve that shuts off hot coolant from the heater core for colder AC.
EDIT: The AIH is the thing just to the right of the boot that looks like a squatty spark plug. I'll be removing mine soon, too. I just looked at how big that thing is in there!! I suggest you get the AIH delete plug with boost line fitting. Much cleaner that way.
Joe
Old Sep 19, 2007 | 06:49 PM
sflem849's Avatar
sflem849
To Hijack - Is it important where you T into the MAP line? My directions said 3" from the map sensor.
Old Sep 19, 2007 | 07:17 PM
Izzy351's Avatar
Izzy351
Don't think so -- can't imagine why it would be. It's just a pressure gauge.
Joe
Old Sep 19, 2007 | 07:26 PM
daleper's Avatar
daleper
Probably just says to put it in there so tech support doesn't get a lot of calls asking where in the line to put it.
Old Sep 19, 2007 | 07:32 PM
countrycar's Avatar
countrycar
I'm with Joe on this. The AIH delete/Boost tie in, is the way to go. I think it's only like 20 bucks or so. I just can't find it. I can't recall which vendor sells it or I'd link it too yah. Joe do you recall the vendor?? Country
Old Sep 19, 2007 | 08:02 PM
ron's power stroke's Avatar
ron's power stroke
here is a good thread from bdrummonds for a DIY AIH kit
https://www.ford-trucks.com/forums/6...ost5040228.html
mine is hooked in the AIH port..you can see the big gold nut on the orange spider pipe.. that is where the AIH is
Old Sep 19, 2007 | 08:07 PM
countrycar's Avatar
countrycar
I tried the thread several times Ron. She won't open. ??? Country
Old Sep 19, 2007 | 08:10 PM
ron's power stroke
thanks Country... lets try this one..
https://www.ford-trucks.com/forums/6...ml#post5040228
Old Sep 19, 2007 | 08:13 PM
countrycar's Avatar
countrycar
YUP! That did it. BD did a great job with this mod install!! Thanks.Country
Old Sep 19, 2007 | 08:15 PM
ron's power stroke
yes..he did a very good job with this..
Old Sep 19, 2007 | 08:44 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I went to Orielly's and bought a oil drain plug the same size as AIH (couple of bucks IIRC), drilled and tapped using same stuff I used for Pyrometer, installed the fitting for the Tee. Stupid AIH gone and gauge tap in a good spot.
Old Sep 19, 2007 | 09:55 PM
bdrummonds's Avatar
bdrummonds
Yeah, Mike, after I did mine I had a buddy want one and since it was a Sat. I went to orielleys and got the 22mm drain plug also. Drilled, tapped, and then sawed off the excess threads of the plug so he would not have a restriction in the Tube. I worked just as well, and more readily available than the fastener store thats not open on weekends.
Old Sep 19, 2007 | 09:59 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
here is another option-
