390 crank not round
What is the thoughts from you engine builders? Am I overly concerned or is this OK to install?
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
would make the rotation smoother rather than a rough
up down resistence being felt.thats my 2 cents ,just a
thought,I ve only taken motors apart
Fe power
>piston connected, tested the rotation drag with a dial
>torque wrench. I get from 10 lbs to 22lbs around the
>revolution when starting from a stand still. I feel it
>should be closer to the same all around.
This is a very unusual test indeed.
Does the piston have rings on ?
What sort of seal does it have ?
What sort of oil did you assemble it with.
This test is unlikely to give any indication of the "roundness" of the crank shaft, that can only be assertained with micrometers.
Palstigauge, will give you the difference in diameter at the point you measured.
I would suggest you are measuring ring drag and the experinecing the effect of changing piston speed that a reciprocating engine endures. Also at the speeds you are turning it you only have hydro-static/ boundary lubrication and no hydro dynamic.
My other engine was
>about 5-7lbs in total.
over stating my thoughts :- why are you emailling and not finishing the assembly.
Crank was poorly ground, egg shaped on the number two journal. Bill
put it his lathe and fixed it. Everything else was OK.
90 in-lbs to start rotation, 25 or so to maintain rotation. Was 25 ft-pounds or 300 in-lbs to start as you recall.
Starting on the timing gears then pistons in a few minutes. Should have it close to done this evening.
Thanks for the replies fellows.
John
jowilker email me
Now I'm bamboozled.
The number 2 crank pin was out of round ? ( or was it a main)
How far ?
How did you get the surface finish by turning it in a lathe
How did you balance the lathe to turn the crank.
Can ya give a "full" rundown on this little saga
Bob is recording the drag on the crank as each piston is added. Don't ask, I don't know why, but the engine is better off now. IMHO
John
jowilker email me
I guess i always did by "feel" the test that is being done as I installed each piston.
But I always measured and checked clearance and roundness with a mic.
Out of round crank grinds are usually the result of "tired" or poorly setup (balanced) grinders.
It is good to understand
