Hard Start
Old Sep 12, 2007 | 02:47 PM
tony mathers's Avatar
tony mathers
Hard Start
My 2002 psd cranks over several revoltions before it starts. I would say at least three times more revoltions than my other 2002 psd or my 95 psd. Air temp doesn't change it. Starting right after shutting off doesn't change anything either. Other wise I think everything works right.
I would appreciate any and all HELP on this.
THANK YOU tony
Old Sep 12, 2007 | 04:41 PM
rbaker6336's Avatar
rbaker6336
if it only turns several revolutions before starting compaired to mine that is easy starting
mine has always turned probly between 10 and 20 revolutions before starting hot or cold
Old Sep 12, 2007 | 06:54 PM
F350-6's Avatar
F350-6
How old is the oil? How old are the batteries? Have you checked the oil level in the HPOP?
Old Sep 12, 2007 | 07:15 PM
zx250's Avatar
zx250
Of the next Riffraff East
You've got some issues. That's way to long.
Old Sep 12, 2007 | 07:33 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
yeah that sounds like you have problem, mine starts after maybe 3 revolution, and thats without glowing plugs in 50-60deg wether
Old Sep 12, 2007 | 07:45 PM
rbaker6336's Avatar
rbaker6336
I'v never started one yet even brand new that startd any faster
Old Sep 12, 2007 | 08:11 PM
zx250's Avatar
zx250
How many seconds are you talking about? Mine usually starts in 1-2 seconds. If its cool and I don't allow time for the WTS light to go off, it my take 3 seconds. I don't know that it has ever taking longer than that unless there was anothern problem going on.
Old Sep 12, 2007 | 08:18 PM
rbaker6336's Avatar
rbaker6336
do the math RPMs required to start devide by 60 X 2 = number ofrevolutions to start
Old Sep 12, 2007 | 08:25 PM
zx250's Avatar
zx250
I don't know. How fast does a starter turn the engine?
Old Sep 12, 2007 | 08:29 PM
rbaker6336's Avatar
rbaker6336
think I remember mne spns about 500rpm
just for kicks take a low easy number 360 rpm
Old Sep 13, 2007 | 09:31 AM
tony mathers
I would say at any time app. 70 deg. MY 95 and my other 2002 will start in 1-2 seconds. My 2002 that is in question here will take 5-7 seconds. It takes long enough that I'm usally letting off the key and try again. The second time it akes just as long. The reason I usally try it twice is because I forget which pick-up I'm in and I let off before it starts. 95 psd ---148,000. 2002 psd---51,000. 2002 that gives trouble has 72,000 miles on it.
Old Sep 13, 2007 | 10:15 AM
rbaker6336's Avatar
rbaker6336
how long have you had this problem
and batteries mentioned before, a battery that is not really good or completely bad will cause a slower start
Old Sep 13, 2007 | 11:34 AM
tony mathers
I just bought this one about three months ago. The cranking speed seems to be as fast and good as my other 7.3 psd.
tonyvivilacqua
Jan 4, 2015 03:30 PM
wmiller
Dec 8, 2009 03:52 PM
tony mathers
15
Aug 26, 2008 01:45 PM
Tony1790
May 4, 2007 12:27 PM
tonyp
Nov 7, 2005 09:22 PM
