oil pan
Old Nov 21, 2002 | 08:48 PM
wickman's Avatar
wickman
oil pan
There are two oil dipsticks on my 360,why? The best I can tell its a 68 year block{c8ae-h on heads,cant find # on block}. I should say one dipstick is in the shallow of the pan and the ather in the belly.
Old Nov 21, 2002 | 09:05 PM
390fe's Avatar
390fe
oil pan
Are you sure you're not jerking the tranny stick out?
If it's not, I don't know what you've got!
Old Nov 21, 2002 | 09:14 PM
wickman's Avatar
wickman
oil pan
No the tranny is a 4 speed .Anyone else have an idea?
Old Nov 21, 2002 | 10:08 PM
BB's Avatar
BB
oil pan
Very weird, your 4x4 should be using the stick in the belly. The other one up front is for the 4x2 pan.
Maybe your motor was replaced with one from a 4x2 or car.
Barry
Old Nov 22, 2002 | 07:18 AM
William's Avatar
William
oil pan
FT oil pans have the dipstick on the right side of the pan about half way back. These pans look like a rectangular box and contain 8 or more quarts of oil. The dipstick in the front is standard for all other FEs. Either one works.
William in Atlanta
Old Nov 22, 2002 | 07:43 PM
wickman's Avatar
wickman
oil pan
Both are on the left side if your looking from the cab forward. Does anyone have any idea on those casting #? Also the belly of the pan is toward the rear of the engine not the front.
Old Nov 22, 2002 | 08:06 PM
BB's Avatar
BB
oil pan
C8AE-H heads were the most popular heads on a FE. They were used on the 360, 390 and 428 engines from '68 to '71 ('70 for the 428).
Barry
Old Nov 22, 2002 | 11:03 PM
stephenw's Avatar
stephenw
oil pan
[updated:LAST EDITED ON 23-Nov-02 AT 00:04 AM (EST)]A 4x4 should have a rear sump 5-quart (plus 1-quart filter)pan, with the dipstick inserted thru the side of the pan. The car/4x2 oil pan is a front sump 4-quart(plus filter), with its dipstick installed into the front of the block next to the filter adaptor. Sounds like you have an engine out of a car, and the pan off a 4x4. Most people install a small freeze-type to plug the hole in the side of the block and ditch the car stick when they install the 4x4 pan, but this way you can measure your oil level two ways!! Steve
Old Nov 25, 2002 | 12:11 AM
Ratsmoker's Avatar
Ratsmoker
oil pan
Old Nov 26, 2002 | 08:08 PM
wickman's Avatar
wickman
oil pan
Ok,360 were not put in cars right.
Old Nov 27, 2002 | 07:31 AM
William's Avatar
William
oil pan
360 ci engines were put in cars. I think you have a better chance of snagging a 390 from a car than a truck, but I always look! You gotta measure the stroke.
William in Atlanta
Old Nov 27, 2002 | 08:16 AM
Ratsmoker's Avatar
Ratsmoker
oil pan
I know dodge put 360's in some of their automobliles but I don't think ford ever put one in a car. There was an old 360 that did go in a car but it was not FE.
Bovaloe
Jan 23, 2010 08:07 PM
Wellcraft
Jan 18, 2005 10:46 PM
fling
Dec 10, 2004 06:10 PM
SShank42
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 7, 2004 05:21 PM
joners
18
Jun 16, 2003 05:36 PM
