Need shaving advice quickly!
Old Sep 2, 2007 | 07:14 PM
  #31
ken's 80's Avatar
ken's 80
Just be extra careful around the kneecaps!!!!
Old Sep 2, 2007 | 07:45 PM
  #32
fl1a's Avatar
fl1a
I shave in the shower also, use a mach 3, and use softsoap liquid soap to wash my face and shave with. I can shave as fast as the 3 stooges could, and have not gotten
nicked since the year the mach 3 was introduced. When I get a days beard growth,
I can wear a t shirt collar ragged in an afternoon, so no yasser arafat beard for me.
Old Sep 2, 2007 | 09:24 PM
  #33
924x2150's Avatar
924x2150
I read the 2nd reply and stopped. Sorry for any repeats.
I have tried alot of razors in my life.
I have terrible skin myself and the double and triple and quadruple razors will only aggravate your skin, I gave up on them after I calmed down from the hype. I believe the actual hair is cut way to sharp and way too low to skin.
Try using bic single blade disposable razors and edge shaving cream.
It isn't the closest shave...but will be easier on your skin
Old Sep 3, 2007 | 09:04 AM
  #34
cdrmotorsports's Avatar
cdrmotorsports
[QUOTE=Nitramjr]If it wasn't for the Air Force and the wife, I'd look like the dude from ZZ TopQUOTE]
If I could, I would!
Old Sep 4, 2007 | 03:44 AM
  #35
1979 Ford's Avatar
1979 Ford
Chemo. When I was taking treatment, that was an advantage. I started shaving about a month after my last treatment.
Old Sep 4, 2007 | 03:27 PM
  #36
I6power's Avatar
I6power
Well i see everyone is still posting here with all sorts of different advice. What i did last time was i followed a combination of mil1lion and kens advice. I kept my face really warm the whole time and i did use one of those rags that ken was talking about. After i was done shaving i used that stuff that mil1ion posted about. Thats good stuff, i didnt get one zit/rash thing. And it was a really close shave didnt cut myself once.
I appreciate everyones input, i really do, but ken and mil1ion had the best advice for me this time.
Old Sep 5, 2007 | 01:04 AM
  #37
Bdox's Avatar
Bdox
I don't do a lot of shaving, just my neck and a little trimming. But I used to have the problem described in the original post.
I know everyone has different beard and skin so no method works best for everyone.
My solution is to shave in the shower using hair conditioner instead of shaving cream products along with the black Bic throwaway.
Old Sep 5, 2007 | 01:00 PM
  #38
Rizvi54's Avatar
Rizvi54
I've been shaving regularly since I was 15 and this is what I have learned. Whenever possible shave in the shower or right after a shower. Get a good razor. Use gel not foam. Shave slow and with the grain. This will not always be down. For example, for some reason under my chin my hair grows sideways. If your beard is thick like mine, shave your face a second time. When done use an aftershave gel, I use Burberry and sometimes Nivea. Hope this helps.
Old Sep 5, 2007 | 01:25 PM
  #39
Mil1ion's Avatar
Mil1ion
So how many of you have one of these and still use it ?
Best shave ever and I have used it for it seems 40 years.
Old Sep 5, 2007 | 02:26 PM
  #40
Rizvi54's Avatar
Rizvi54
Looks like something out of Little Shop of Horrors.
Old Sep 5, 2007 | 03:23 PM
  #41
bigdaddyII's Avatar
bigdaddyII
I have one of those. However, it was my grandpas and I havent the first idea how to use it. It does look cool though.
Old Sep 5, 2007 | 03:49 PM
  #42
Mil1ion's Avatar
Mil1ion
Working it is fine. twist bottom to open double edge blade compartment.
adjust shaving closeness by turning the numbered wheel.
Find a store with replacement blades is the tough part
Every time I see them in a museum display I ask: "How much for those ?"
Old Sep 6, 2007 | 08:13 AM
  #43
TheHandyman's Avatar
TheHandyman
Thumbs up love these tough car questions :)
hey dude, hope it all went ok
I was told to shave down, not against the hair. to only make one pass. to hold the razor lightly between 2 fingers (so as not to press it too hard) I still use 3 fingers tho...
the blade must be clean and sharp. rinse & shake water out after use so no rust or scuzzy stuff forms (that can bring lotsa infections)
Honestly now i use antibacterial liquid hand soap to shave. it kills the germs that infect those lil cuts. Before I used that I had to wipe my whole neck with rubbing alcohol.
As we shave we'll always get little cuts normally. Its these lil cuts that get infected and swell up in bumps (yuck! had that!) if you wipe with alcohol right after you shave it kills those germs and the lil cuts heal quick without swelling pain or redness. Or shave with antibacterial soap kills it as soon as you cut it.
Hope this makes sense, it sure works for me
Old Sep 6, 2007 | 03:17 PM
  #44
deltasoft's Avatar
deltasoft
thats wut i do. i trim mines and leave as gotee..Wife likes the gotee....wish i could shave it off though...lol my electric shaver is branded Peanut. then use for sides of face gillete fusion and use a battery trimmer (cheap from walmart) to keep in shape...
Hope helps.
Old Sep 6, 2007 | 04:05 PM
  #45
driximus's Avatar
driximus
Wish i could hep but i grow little facial hair, So little All i need is a razor and some water and shave with that im good for ussually 2 days.
I6power
22
Sep 17, 2007 01:20 AM
rywegh
Apr 25, 2006 09:47 AM
cjben
Apr 17, 2006 09:16 AM
unclehan
19
Jan 24, 2006 11:36 PM
150ford
18
Jun 10, 2005 08:44 AM
