cab lights
Old Aug 22, 2007 | 12:38 PM
southernman1989's Avatar
southernman1989
cab lights
i biught and installed a new set of cab lights on my 1995 extended cab truck and i can not figure out how to connect the cab lights wire to the headlight switch next to the steering wheel. would any of yall have any idea on how to do this?
Old Aug 22, 2007 | 01:26 PM
southernman1989
ive tried every thing, even just putting the wire straight into the fuse box, the only result i got out of that was a blown fuse.
Old Aug 22, 2007 | 02:54 PM
mgraveman's Avatar
mgraveman
If that happened you've got a short somewhere. The factory plug is behind the passenger side kick panel.
Old Aug 22, 2007 | 04:12 PM
southernman1989
would i just have to splice the two wires together?
Old Aug 22, 2007 | 04:47 PM
F150xlt's Avatar
F150xlt
Here's the diagram for an 88. Your 95 should be similiar.
One wire is connected to ground and the other wire goes to the Headlight
switch so when the Headlight switch is in the Head or Park position, 12 volts is applied to the cab lights.
Old Aug 22, 2007 | 09:21 PM
atillett's Avatar
atillett
on most they have to be grounded on the lights to the metal with screws directly to the metal. at least on aftermarket lights. there is a wire behind the drivers side kick panel it will have a female terminal. if you use a spade blade you will have to grind or file it down a little. this was my experince on a 88 f-250.
Old Aug 22, 2007 | 09:40 PM
OldRed4X4's Avatar
OldRed4X4
i was just in there to day and i wonder if u can buy a conecter somewhere to fit it
Regulator1988
Mar 30, 2012 06:43 PM
steensm
Mar 7, 2012 07:38 PM
biggcountry235
Appearance & Dress-Up
Jun 10, 2008 08:18 PM
FarmingFord
Jun 6, 2008 03:22 PM
SoConSick
Electrical Systems/Wiring
Feb 22, 2005 07:46 PM
