cab lights
Old Mar 28, 2012 | 01:00 PM
Regulator1988's Avatar
Regulator1988
cab lights
when i bought my truck it didnt have cab lights does anyone know how to install or what i nee to install them
Old Mar 28, 2012 | 01:03 PM
Snuggyworm's Avatar
Snuggyworm
do a google search. u'll find detailed instructions as well as the lights u wan.
Old Mar 28, 2012 | 01:07 PM
f250rangerexplorer's Avatar
f250rangerexplorer
I installed all ford oe stuff on my f250 and it was about a 3hr job. Taking my time. The factory plug is behind the pass side interior kick panel and the clips all snapped right in place. Placement was easy for me as i had my 99 dually next to it for measurements. Best thing next to a leveling kit i did for the looks of it. I believe everything cost me right about $125.
Old Mar 28, 2012 | 01:21 PM
Regulator1988
where did you get the stuff?
did you have to take the headliner off?
Old Mar 28, 2012 | 01:44 PM
f250rangerexplorer
I purchased all my stuff at my local dealer (gridley, ca ford) With the exception of some sealant for the base of the lights. The headliner wasnt bad but i didnt have a overhead console either. Took the visor and trim pieces down and it was out. 10 min job to get to the bare steel roof. Another 5 mins hooking Up the wiring and about 1hr 30m driloing measuring and centering everything. Use masking tape and mark and measure you lines with it. Only way to go. The last hour was reassembly and admiring the lights glowing as the sun went down lol. Best $130 i ever spent on that truck
Old Mar 28, 2012 | 01:59 PM
Regulator1988
so i need
lights
harness
and what else
is there a switch for the lights to come on>
Old Mar 28, 2012 | 02:03 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here is a good link:
Motoman's Madness
Old Mar 30, 2012 | 12:00 AM
f250rangerexplorer
The Perks of using the factory harness is that it runs off the headlight switch just as it would if the factory installed them.
Old Mar 30, 2012 | 09:34 AM
Regulator1988
thats what i think i will do
Old Mar 30, 2012 | 10:55 AM
Kert0307's Avatar
Kert0307
If you do some searching you can get the Recon LED kit (comes in smoked, and clear covers also) with the harness for around $90
Old Mar 30, 2012 | 12:19 PM
Regulator1988
this kit comes with the harness! really? that will plug into the factory plug?
Old Mar 30, 2012 | 01:11 PM
Kert0307's Avatar
Kert0307
Some do, but not all of them. You need to make sure you look at the fine print...
Edit: According to their website, they all should come with the harness.
http://www.gorecon.com/product.php?p...uperduty-99-12
Old Mar 30, 2012 | 03:09 PM
Regulator1988
i fount it on e bay for 80
Old Mar 30, 2012 | 03:25 PM
2006powerstroke90's Avatar
2006powerstroke90
I bought a kit for my Duramax....
Recon lights were $100 and the wiring kit was 40$ worth it all day long...
The smoked lenses go great with my black truck, and the LEDs look great at night.
Old Mar 30, 2012 | 03:27 PM
Regulator1988
I have a tan truck
You think black will look good?
