Y-Pipe to X-pipe??
what you have described is known as a cat back system, where from the catalytic converters back things are changed but manifolds and collectors and cats are untouched (this type makes for better sound but offers little performance gain)
definantly get a better exhaust i sujest H pipe with bullet type mufflers (or better yet, none), and long tube headers, ditch the cats (unless you have an emmisions inspection/testing in your area, in which id at least sujest short tubes if you MUST retain the cats)
As for cats restricting the flow, I measured the exhaust velocity and emissions output at the muffler inlet with the Bassani catalytic converter and without. There was a miniscule difference in velocity without the catalytic converter (less than 1%... this wouldn't translate to even 1 horsepower)
However, the emissions content was up to 20x higher for certain hydrocarbons without the catalytic converter. The hydrocarbons you emit without catalytic converters are extreme greenhouse gases that have no natural process to break them down into soluble carbon forms. That is, some of these compounds will not break down in your lifetime, or your grandkids.
Do us all a favor who share this planet and run your system with a catalytic converter, even if you don't require emissions checks. A decent stainless-steel high flow converter costs $60-75.
Just because the stock cats are restrictive, doesn't mean you shouldn't replace them with a worthy setup. Your truck isn't going to pull any different with a well made cat matched to your exhaust system.
There is a reason many locales do require emissions tests. Some vehicles should not be driving our roads. A little responsibility goes a long way...
Mike
Mike
and my truck shouldnt be driving your roads, thats why its not, its driving my roads!
The exhaust system on these trucks has to run down the passenger side, so an X pipe won't give the scavenging benefits you get on a car where the crossover is the same distance from each bank. 2 cats, 2 mufflers, it's all just extra cost for no real benefit, especially since anything bigger than a mendrel bent single 2.5" system will hurt low rpm performance. There is just not enough performance in these motors to warrant all that plumbing, unless you have heads, cam, and maybe a blower on it. The 5.0 Mustangs came with dual 2.25" exhaust, and that motor made more power stock than any of the 5.0 truck versions. Don't get carried away with hanging monster big pipes under your truck.. it'll hurt more than it helps.
The stuff you let sneak by out of your emissions is not only a detriment to the ozone layer, but everything the PAH's and PCB's dissolve in.
I don't have to run a catalytic converter either. But being that you can run one without bottlenecking the power output of your truck.... There is no logical reason you shouldn't run one.
If you still think running without one is justified, step outside your bubble and do some research.
Get your emissions in check. Every little bit helps
Mike
Three-way catalytic converters
A three-way catalytic converter has three simultaneous tasks:
- Reduction of nitrogen oxides to nitrogen and oxygen: 2NO<sub>x</sub> → xO<sub>2</sub> + N<sub>2</sub>
- Oxidation of (non greenhouse gas, but toxic) carbon monoxide to less harmful (greenhouse gas) carbon dioxide: 2CO + O<sub>2</sub> → 2CO<sub>2</sub>
- Oxidation of unburnt carcinogenic hydrocarbons (HC) to carbon dioxide and water: 2C<sub>x</sub>H<sub>y</sub> + (2x+y/2)O<sub>2</sub> → 2xCO<sub>2</sub> + yH<sub>2</sub>O
Since 1981, three-way catalytic converters have been at the heart of vehicle emission control systems in North American roadgoing vehicles, and have been used on "Large Spark Ignition" engines since 2001 in California, and from 2004 in the other 49 states. LSI engines are used in forklifts, aerial boom lifts, ice resurfacing machines and construction equipment. The converters used in these are three-way types designed to reduce combined NO<sub>x</sub>+HC emissions from 12 gram/BHP-hour to 3 gram/BHP-hour or less, per the United States Environmental Protection Agency (EPA) 2004 regulations. A further drop to 2 gram/BHP-hour of NO<sub>x</sub>+HC emissions is mandated in 2007 (note: NO<sub>x</sub> is the industry standard short form for nitric oxide (NO) and nitrogen dioxide (NO<sub>2</sub>) both of which are smog precursors. HC is the industry short form for hydrocarbons). The EPA intends to introduce emissions rules for stationary Spark Ignition engines, to take effect in January 2008.
Two-way catalytic converters
A two-way catalytic converter has two simultaneous tasks:
- Oxidation of (non greenhouse gas) carbon monoxide to (greenhouse gas) carbon dioxide: 2CO + O<sub>2</sub> → 2CO<sub>2</sub>
- Oxidation of unburnt hydrocarbons (unburnt and partially-burnt fuel) to carbon dioxide and water: 2C<sub>x</sub>H<sub>y</sub> + (2x+y/2)O<sub>2</sub> → 2xCO<sub>2</sub> + yH<sub>2</sub>O
Curiously, the regulations regarding hydrocarbons vary according to the engine regulated, as well as the jurisdiction. In some cases, "non-methane hydrocarbons" are regulated, while in other cases, "total hydrocarbons" are regulated. Technology for one application (to meet a non-methane hydrocarbon standard) may not be suitable for use in an application that has to meet a total hydrocarbon standard. Methane is more difficult to break down in a catalytic converter, so in effect a "non-methane hydrocarbon" standard can be considered to be looser. Since methane is a greenhouse gas, more interest is rising in how to eliminate emissions of it.
Polycyclic Aromatic Hydrocarbons (PAHs)
This pamphlet provides answers to questions about polycyclic aromatic hydrocarbons. It will explain what polycyclic aromatic hydrocarbons are, where they are found, how they can affect your health, and what you can do to prevent or reduce your exposure to them.
Polycyclic aromatic hydrocarbons (PAHs) are chemicals that are made when substances are burned. You can be exposed to PAHs by breathing smoke, eating foods that have been grilled or by coming into contact with soil containing PAHs. Some PAHs may cause cancer and may affect the eyes, kidneys and liver.
What are PAHs?
PAHs are a group of chemicals that occur naturally in coal, crude oil and gasoline. PAHs also are present in products made from fossil fuels, such as coal-tar pitch, creosote and asphalt. When coal is converted to natural gas, PAHs can be released. Therefore, some coal-gasification sites may have elevated levels of PAHs. PAHs also can be released into the air during the incomplete burning of fossil fuels and garbage. The less efficient the burning process, the more PAHs are given off. Forest fires and volcanoes can produce PAHs naturally.
Although hundreds of PAHs exist, two of the more common ones are benzo(a)pyrene and naphthalene.
How can I be exposed to PAHs?
PAHs are found throughout the environment in the air, water and soil, and can remain in the environment for months or years. Levels of PAHs in urban air may be 10 times greater than those found in rural areas. You also may be exposed to PAHs in soil near hazardous waste sites or near areas where coal, wood, gasoline or other products have been burned. Some water supplies in the United States have been found to have low levels of PAHs.
In the home, PAHs are present in tobacco smoke, smoke from wood burning stoves and fireplaces, creosote-treated wood products and some foods. Barbecuing, smoking or charring food over a fire greatly increases the amount of PAHs in the food. Other foods that may contain low levels of PAHs include roasted coffee, roasted peanuts, refined vegetable oil, grains, vegetables and fruits. A variety of cosmetics and shampoos are made with coal tar and therefore may contain PAHs. The PAH compound naphthalene is present in some mothballs.
How can PAHs affect my health?
The health effects that can be caused by exposure to PAHs depend on --
* how much has entered your body,
* how long you have been exposed to PAHs and
* how your body responds to PAHs.
It is not clear whether or not PAHs cause short-term health effects. Other chemicals commonly found with PAHs may be the cause of short-term symptoms such as eye irritation, nausea, vomiting, diarrhea and confusion.
Possible long-term health effects caused by exposure to PAHs may include cataracts, kidney and liver damage and jaundice. Repeated skin contact with the PAH naphthalene (found in some mothballs) can result in skin redness and irritation. Breathing or swallowing large amounts of naphthalene can cause the breakdown of red blood cells.
Some people who have breathed or touched mixtures of PAHs and other chemicals for long periods of time have developed cancer. Some PAHs have caused cancer in laboratory animals when they breathed air containing them (lung cancer), ingested them in food (stomach cancer) or had them applied to their skin (skin cancer).
How can I reduce my exposure to PAHs?
One of the greatest sources of exposure to PAHs is breathing these chemicals in tobacco smoke. Smokers can lower their own exposure and the exposure of their families by stopping smoking. Additional steps to lower exposure to PAHs include –
* eating less smoked and charbroiled foods;
* reducing the use of wood burning stoves and fireplaces;
* decreasing the use of coal-tar-based cosmetics and shampoos;
* using cedar shavings or aromatic herbs instead of mothballs, moth flakes and deodorant cakes; and
* when handling creosote-treated wood products, avoid skin contact by wearing protective clothing, such as long-sleeve shirts, long pants and gloves.
What can medical tests tell me about my exposure to PAHs?
Tests are available to measure the presence of PAHs in blood or urine. These tests cannot be used to predict possible health effects, but can only show that you have been exposed to PAHs. These tests are not routinely available at a doctor's office because they require special equipment. Some hospitals can provide this testing. If you think you might be ill from exposure to PAHs, contact your doctor.
Where can I get more information?
Illinois Department of Public Health
Division of Environmental Health
525 W. Jefferson St.
Springfield, IL 62761
217-782-5830
TTY (hearing impaired use only) 800-547-0466
This pamphlet was supported in part by funds from the Comprehensive Environmental Response, Compensation, and Liability Act trust fund through a cooperative agreement with the Agency for Toxic Substances and Disease Registry, Public Health Service, U.S. Department of Health and Human Services.
On my 88, it was two pipes comming from the manifold, a small H pipe where the o2 sensor sits and goes into the resonator, to a cat and then the exhaust. I cut right before the resonator and ran 2 1/2" piping all the way back with two dynomax ultra flo mufflers. About 2 months ago I put an X pipe and got noticeable performance, but it cut the sound down A LOT so it sounds like a y pipe. I don't like that. Put the X pipe as far forward as possible.
I cant see very much performance gains for what yo have now when you put two cats and two mufflers. The ultra flo mufflers are basically a glasspack but with a lifetime warranty. Probably one of the highest flowing mufflers. If I remember right, its 600 cfm more then flowmasters
The point was, this was one of the hydrocarbons that emit from the combustion of organic materials. I chose this one, because there is a direct link to us boys and our prostates. Apparently, that didn't hit home.
True, there are other ways this compound is introduced, but un-checked vehicle emissions is something we can directly effect. Similarly to methane derivitaves, vehicles are not the only guilty party. This can be said for many of our pollutants.
The big picture here is, there is no excuse why anyone should not be running a catalytic converter. Not whether PAH's or methane like compounds are the culprits to contamination. Or whether the catalytic converter search yielded no results about PAH's. PAH's by itself is a generic term that describes numerous compounds, most of which can occur naturally at very low levels.
Also, EPA regulates little in regards to PAH's in internal combustion vehicles. Especially in comparison, to CO (carbon monoxide) and NOx derivitaves.
There is still no logical reason one would not run a catalytic converter on their vehicle.......
Mike
It takes years often decades before the FDA will allow this kind of research to be broadcasted to the American Public. Especially, when these kind of decisions will have major commercial market effects.
We still can't share results regarding Orthotrycyclene (Birth control pills) and breast cancer in women. This is common knowledge in the medical field that years of hormone intake, has a direct link to breast cancer. This has been published in the American Journal of Medicine, British Journal of Medicine and many other accredited journals. Yet many of the public have no knowledge of this. And, Orthotricyclene is still given out to your mothers, sisters, and friends.
How long did it take for cigarettes to become listed with the surgeon general's warning? Many years after medical journals published results regarding its impacts.
Just because your google search did not produce results regarding the link between PAH exposure and prostate cancer in men, does not mean it doesn't exist.
Let me reiterate, this is ongoing, on the cusp research. Not 25 yr. old chemistry rhetoric regarding PAH's. Go to a library and do a real search in medical journals. Don't just hit PAH in google and copy and paste......
Good Luck,
Mike
Mike
