hard to start!!
Old Aug 22, 2007 | 06:15 AM
baredog26's Avatar
baredog26
hard to start!!
I have a 99 F-550 with 7.3 powerstroke. I have no modifications. When I start the truck it seems like it's down a cylinder, but after running for 5-10 minutes it smoothes out and runs fine. I've used my scan tool on it and it shows no codes, and all cylinders are passing the contribution test. I replaced glow plugs last winter, and that never helped. Anyone have this problem before? The truck does this worse in cold temps but it will also act up above 60 degrees.
Old Aug 22, 2007 | 10:43 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Did you replace the glow plug relay when you did the plugs? Does it smoke any during that 5-10 minute warm up?
Old Aug 22, 2007 | 01:18 PM
Action4478's Avatar
Action4478
What kind & weight oil are you running?....
Old Aug 22, 2007 | 01:37 PM
baredog26's Avatar
baredog26
yes I replaced the relay. smokes just at first fire, when it's colder outside. I run caterpillar 15w40 oil
Old Aug 22, 2007 | 01:51 PM
Action4478's Avatar
Action4478
You might consider a 5w oil or a synthetic or both....
Old Aug 22, 2007 | 03:03 PM
Kwikkordead's Avatar
Kwikkordead
I have a '99 F550 as well. This may be your problem too.
https://www.ford-trucks.com/forums/2...or-wiring.html
96_F250_Deezal
Oct 1, 2013 07:46 AM
chrisoroe
May 29, 2011 11:41 PM
clutter
Dec 9, 2009 08:56 AM
yamahead
Jul 9, 2009 12:10 PM
Rob88
Feb 20, 2000 07:02 PM
