lifter break in
Old Aug 20, 2007 | 08:11 AM
splittinhairs's Avatar
splittinhairs
lifter break in
OK, installed my used cam with very little time on it. Its a solid lifter cam and switching over the hyd valvetrain to solid lifter system with adj rockers and new heavyer springs, double spring I believe. When I break in the lifters do I need to just use one spring or can I get by using the double spring just to break in lifters?
Old Aug 20, 2007 | 09:00 AM
FalconStng's Avatar
FalconStng
It's generally recommended to breakin a cam with a lower spring rate. Most people, including myself, don't do this. The more radical the cam, the more this becomes necessary....given all the issues with flat tappet cams and lifters these days I believe I'd go with the one spring.
Good Luck
Tracy
Old Aug 20, 2007 | 03:39 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
How used is the cam? Lifters brand new?
Old Aug 20, 2007 | 04:04 PM
splittinhairs
Cam is used but very good shape, had it checked. Lifters brand new.
Old Aug 20, 2007 | 04:22 PM
FalconStng's Avatar
FalconStng
hmmmmm....I don't have an answer for you. I believe the breakin has a lot more to do with the cam than the lifters and if your cam is used then you don't need to do the breakin....however I'm guessing on this...someone else needs to elighten us both.
Tracy
Old Aug 20, 2007 | 07:54 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
I think to be safe I'd still treat it as it's new. New lifters are convex and will wear to the pattern of the old cam as they spin. There is also some hardening that happens over time that raises rockwell as the pattern spreads out with new cam and lifters. With some of the oils that are on the market today you need to be careful. And I'd also use a break-in additive and some assy prelube just to be safe. Are your springs true dual coil with a damper?.... or a coil with a damper spring inside? Call me cautious on this one.
Old Aug 20, 2007 | 09:12 PM
baddad457's Avatar
baddad457
Inspect the new lifter bottoms too, this has been the cause of more than a few of the failures lately------bad lifters.
Old Aug 21, 2007 | 08:29 AM
splittinhairs
springs are Crane #96870-16, retainers are #99969-16 & locks are #99099-1. Thanks for your advice so far.
Old Aug 21, 2007 | 09:21 PM
390cobrajet's Avatar
390cobrajet
also, arent you supposed to block off one of the oil galleys when switching to solids on an FE? enlighten us.
Old Aug 21, 2007 | 09:37 PM
baddad457's Avatar
baddad457
It's a good idea to, but some have gotten away with not doing it. One look at the dumbell lifters was enough for me to pull the galley plugs and install restrictors on the 68 427 I had.
Gore0199
Jun 1, 2016 06:46 PM
billyrayf150
Feb 13, 2016 11:50 AM
ragman69
Nov 3, 2010 10:00 AM
Firemudder
Apr 13, 2007 12:48 PM
Tmod700
May 6, 2005 09:42 PM
