Engine rebuild, lifter noise
Old May 31, 2016 | 09:54 PM
Gore0199's Avatar
Gore0199
I just rebuilt my 302 in my 96 F150 and I installed a larger cam while it was apart. I used comp xtreme energy cam part # 35-512-8 I also used all the recommended lifters, push rods, springs, timing set, etc. through comp. started it up and performed the break in on it and have driven it some since then. I still have some lifter noise and I am wondering if any one else has experienced this, is it normal? I was told with the larger cam it is normal for the lifters to make noise. I just want to know other people's thoughts/inputs about this.
Old Jun 1, 2016 | 06:12 AM
'89F2urd's Avatar
'89F2urd
Define lifter noise please
Old Jun 1, 2016 | 06:54 AM
Gore0199's Avatar
Gore0199
Ticking noise
Old Jun 1, 2016 | 07:36 AM
'89F2urd's Avatar
'89F2urd
Have you checked oil pressure? No way it can be an exhaust leak?
Old Jun 1, 2016 | 08:02 AM
Gore0199's Avatar
Gore0199
Yeah good oil pressure, also there is an exhaust leak but I can differentiate the lifter noise from the exhaust leak
Old Jun 1, 2016 | 08:32 AM
'89F2urd's Avatar
'89F2urd
What were your oil press readings? Does the tick go away/lessen with rpm or oil press increase ?
Old Jun 1, 2016 | 09:09 AM
Scndsin's Avatar
Scndsin
Is it heat/cold related?
Can you pull the valve cover & run it to isolate the particular one?
Are you using new rockers or the originals, stock or aftermarket?
Old Jun 1, 2016 | 09:22 AM
Gore0199's Avatar
Gore0199
Both sides, hot and cold, stock rockers
Old Jun 1, 2016 | 09:33 AM
'89F2urd's Avatar
'89F2urd
Both sides!? Like you have more than one tapping?
What heads; and were they milled? How much? I ask because of pushrod length.
Too much spring pressure can collapse a lifter, but they'd have to be springs for duration in the 235+ .600 lift range.
You could have one bad lifter out of the box, two? Possible but unlikely. More? Verrrry doubtful.
If nothing else is glaring, oil pressure is the likely culprit.
Old Jun 1, 2016 | 11:21 AM
Scndsin's Avatar
Scndsin
^^^ What he said about push rod length.
I'd pull the upper intake, both valve covers, carefully check & mark distributor, pull it, then plug in a prelube drive shaft to the oil pump & run the crap out of it while watching what & how much come out of the push rods onto the rockers.
If you reused the rockers, did you keep them with their fulcrums? They are wear mated & mixing them up can make for "ticks".
Old Jun 1, 2016 | 05:13 PM
Gore0199's Avatar
Gore0199
I went off the gauge in the cluster it's in the normal range. I can't hear it driving it down the road but it's hard to hear the lifter noise with the vehicle off idle due to the exhaust leak.
Old Jun 1, 2016 | 05:17 PM
4DB's Avatar
4DB
Fix all the exhaust leaks first! Then see where you're at.
Old Jun 1, 2016 | 06:46 PM
'89F2urd's Avatar
'89F2urd
The gauge in the cluster is not real, it might as well be a light that turns on and off if it reads any pressure.
Gotta hook up a mechanical gauge if you want to know what it really is.
Brando_21
Apr 26, 2010 02:46 PM
68 351 bronc
1983 - 2012 Ranger & B-Series
Dec 7, 2007 09:15 AM
CHILIDOG6245
Feb 27, 2004 07:53 AM
