390 Oil Problem
Old Mar 10, 2005 | 06:02 PM
EarlDale'sFords's Avatar
EarlDale'sFords
390 Oil Problem
I have a 69 F250 with a 390 in it, and I'm having some oil isssues. Engine only has about 20,000 on it and has had no problems so far, but suddenly its been losing a lot of oil. Three times now it has run down far enough to make the engine start rattling, but I never saw any major oil leak anywhere in my driveway or in any parking lot, except for maybe a few tiny dribbles. This time, when I was putting oil in it, I put in almost 2 and half quarts, and noticed that all of the FRESH oil was leaking right onto the ground, from somewhere in the rear of the engine. Can anyone give me an idea of exactly what the problem might be, my guess is that it is leaking from somewhere on top of the rear seal so that it doesn't leak when its parked but only leaks when the oil is completely full or when I'm driving. Any other ideas?
Old Mar 10, 2005 | 06:49 PM
rusty70f100's Avatar
rusty70f100
Sounds like valve cover gaskets. The fresh oil gave it away. Have you got the stamped steel ones? Those are notorious for leaking. A set of aluminum ones will fix things up nicely. DSC has nice looking Ford Racing valve covers for about $110.
Old Mar 10, 2005 | 08:46 PM
ford390gashog's Avatar
ford390gashog
yep sounds like valve covers they only leak at high rpms or when filling the engine because it pumps so much oil up there
Old Mar 10, 2005 | 08:52 PM
plowpusher's Avatar
plowpusher
is the bottom of the truck covered with oil? valve covers, back of intake manifold in the valley seal area or mabye a cut rear main seal wash the motor get a mirror and spend sometime looking
Old Mar 11, 2005 | 09:37 AM
FalconStng's Avatar
FalconStng
my 390 had major oil leaks as well. The valve cover gaskets were a big part of the problem. They can be made to seal but I agree that aluminum valve covers is the way to go...I've already purchased the ford racing ones myself. I also discovered that the oil dipstick tube had a major crack at the base of it that allowed alot of oil to leak out when the engine was running.
Old Mar 11, 2005 | 10:43 AM
rusty70f100
If it winds up on the ground when he pours it in the valve cover with the engine off, where else is it going to possibly come out? Really? Unless he left the drain plug off.
Old Aug 20, 2007 | 08:21 PM
orich's Avatar
orich
Aw Someone with there eyes closed can see that Good call rusty..
my 2cents also..
orich
Old Aug 21, 2007 | 09:55 PM
390cobrajet's Avatar
390cobrajet
ya I woulnt think it would be the intake at the rear since the oil would have to pool in the valley to leak there, cant do that unless at a severe angle. but wow, thats some leak if it drains out like that! valve covers must be ready to fall off or gasket got blown to bits. so it should leak down the sides as well then, since it pools there in the head first then to the front and back.
RedDevil460
Jan 11, 2014 08:36 AM
79250ranger
Apr 16, 2012 05:29 AM
blaze42069
Oct 28, 2010 06:35 PM
6lpowerstrokesrj
Dec 10, 2007 06:47 AM
F0rdF0rever
1983 - 2012 Ranger & B-Series
18
Nov 19, 2005 07:34 PM
