DIY injectors
Old Aug 21, 2007 | 10:55 PM
  #46
Casserly's Avatar
Casserly
Originally Posted by c00nhunterjoe
i thought stage 2's are the same as one's but with the bigger nozzles?
Partially correct. Depennding on who you buy your injectors from depends on whether or not that statement is true. Some "Stage 1" injectors flow less fuel than there "Stage 2" injectors. Other companies utilize the same injector but put different nozzles on the injectors.
On the larger nozzles, the nozzle holes are opened up more to allow the fuel to be released out of the injector in less time. More fuel in the cylinder in a shorter amount of time allows for a bigger explosion. Fuel needs to be pushed out in a timely fashion or you will not see the complete gain of the injectors.
Old Aug 21, 2007 | 11:15 PM
  #47
RubberDuck's Avatar
RubberDuck
Well said sir.
Old Aug 22, 2007 | 08:34 AM
  #48
strokin'_tatsch's Avatar
strokin'_tatsch
ok then why is the diy-kit so much more for the stage II's than the stage I's. if i could get the stage I kit and some stage II nozzle's for fairly cheap then that would be awesome, but i don't THINK that's going to happen.
Old Aug 22, 2007 | 03:16 PM
  #49
Neal 97 250's Avatar
Neal 97 250
I believe the difference in cost is the nozzles.
Old Sep 6, 2007 | 09:22 AM
  #50
fuelman's Avatar
fuelman
Question about the intencifer piston do these need to be machined by a shop or can you do it your self?
Old Sep 15, 2007 | 10:30 PM
  #51
BigCrzyRdNeck's Avatar
BigCrzyRdNeck
i was wondering what kind of milage you guys got before the injectors and now afthr. i get 15 on my best days no matter how easy i drive and 12 on the normal days when i leave the line before the guy on the bicycle. i have a power 3 programer and straight exhast 3". every one i talk to says they get 18 at 55 i did for a month and got 15. any help thanks
Old Sep 16, 2007 | 10:47 AM
  #52
1997F-350's Avatar
1997F-350
you can do them yourself if you got the tools.
you can also do your injectors yourself with out the diy kit if you got the time.
me and "JOAT" where going to do this and where talking about in a thread and had all we needed. it wasnt a week or two later the diy company started up.
in the end i had no time and was in the process of moving so i sent mine to casserly.
cool of you to come on here and share some info.
if you want the info send me a pm and i will send you a few links. the info is out there you just gotta know how to find it.
ryan are you and the other ryan still under one roof? i think i got two injectors not firing.(i need to hook up the lap top here soon).
Old Sep 16, 2007 | 05:09 PM
  #53
79F150EFI's Avatar
79F150EFI
i wonder if you could get diy-stage 1's and some stage 2 nozzles and see an increase in power. just thinking out loud, but if you get bigger nozzles then a little more fuel is allowed into the cylinder allowing for more power and smoke.
That is what I did. Even though the Stage 2's flow 20cc's more, DIY told me that difference is only in numbers of who wants the biggest mathematical flow and will show no real world power difference. So, yes, you can do that. It doesn't really save any money though.
Old Sep 18, 2007 | 10:08 AM
  #54
Casserly's Avatar
Casserly
No I'm out next to my house now. It's about 20 min from Ryan though.
Let me know whats going on and I'll get you takin care of.
Old Sep 18, 2007 | 02:13 PM
  #55
1997F-350's Avatar
1997F-350
will do man thanks ill send you a pm once i see whats going on.
hndamxmn
Jul 1, 2009 11:05 AM
foxracing0934
22
Apr 30, 2008 10:21 PM
BigDog83
21
Apr 25, 2008 03:40 PM
bigbadwolfe
18
May 20, 2007 07:02 PM
RÖENTGEEP
Mar 28, 2007 10:26 PM
