Louder Exhaust?
Old Aug 25, 2007 | 11:22 AM
  #31
Mr. M's Avatar
Mr. M
Originally Posted by Skandocious
And we find great pleasure in watching these engagements Mike
Muy excellente. Glad to be of service
Old Aug 25, 2007 | 03:16 PM
  #32
Talyn's Avatar
Talyn
I have to be good now I'm a CL. =(
Old Aug 27, 2007 | 02:46 PM
  #33
timberon94f350's Avatar
timberon94f350
Talking
I would keep the cat on & just ram the guts out of it. I took the cat off my 94 with a 460 & put 18 inch 2 1/2 in diameter glass pack that exit between the cab 7 te rear tire. It is WAY too loud. You can not drive with passenger wndow down. Get some thumbs up though!
Old Aug 27, 2007 | 05:09 PM
  #34
flareside_thunder's Avatar
flareside_thunder
I never noticed it was two different threads before...hmmmmm does this mean I can't go commando anymore or does my underwear filter my methane fumes?(god help you all in my presence)As opposed to blowing out a cat, if you blow out your undershorts...you've got bigger problems.Now now ladies.....have some tea and crumpets.
Old Aug 27, 2007 | 08:32 PM
  #35
myakkacracka's Avatar
myakkacracka
if you want loud get the single chamber off road flowmaster
Old Aug 27, 2007 | 08:57 PM
  #36
flareside_thunder
I still vote for the Dynomax race bullet.....
Old Aug 27, 2007 | 10:18 PM
  #37
Talyn's Avatar
Talyn
Screw it.
Strait pipes!
Go 4 inches or even 5 after the cat.
use the cat to make some backpressure for you.
Wide open afterwards.
Throw in a smoke screen type rig too.
SO you can blast oil into the tail pipe and burn a big smoke screen.
Then! make it so you can shoot flames out the baby! that would be, smokey, loud and pimp. =)
When the ricers pull up behind you, you can burn their paint, and smoke them into oblivion...
Old Aug 28, 2007 | 11:14 AM
  #38
timberon94f350
The cat also makes a great resonating chamber if you do this. I know this because I used to build exhausts. One time we run 3 1/2 dual exh. into 5 1/2 strait stacks way too loud! Set off car and bank alarms.
Old Aug 31, 2007 | 11:09 AM
  #39
White Mike's Avatar
White Mike
From what I understand the 50 Series Flowmasters were originally designed to be used with vehicles without cats, that's why the muffler has a third chamber (called a tuning chamber). If you are retaining you cats (performance,stock, or otherwise) the 40 series is the way to go. Also, the larger the pipe diameter, the louder it gets. Just my two cents, I have a 7.3 Diesel in my F250, and the turbo quiets it down so much I'm considering removing the Banks muffler and straight piping it, and my truck never had a cat to begin with.
Old Aug 31, 2007 | 05:55 PM
  #40
Dean88's Avatar
Dean88
Well, I put true duals on my '87 with stock manifolds and 30" cherry bomb glasspacks, and it is loud, also I learned that a good set of tips will change the sound. You might want to just go ahead and get a whole new exhaust done, and try to keep the pipes as STRAIGHT as possible if you want loud. Removing your cat completely is a much better path, because I had gutted cats on mine, then I went ahead and removed them after one got a hole in it, and it definatly made it sound better.
Old Sep 3, 2007 | 02:31 PM
  #41
flareside_thunder
Longer tips will give you a deeper more aggressive tone as well......
Old Sep 3, 2007 | 09:23 PM
  #42
Louisianaforddriver's Avatar
Louisianaforddriver
Like these? I ordered me sum of these pupies!
http://www.jegs.com/webapp/wcs/store...-1&showValue=1
Acutally mine are the ones that are 24 inches long. They dont have a pic of mine!
Filthy1955F100
Oct 16, 2013 09:40 PM
lyinlow
Apr 8, 2012 08:50 PM
Trevor.801
Nov 6, 2011 07:13 PM
Bonesofsteel
2004 - 2008 F150
Feb 2, 2010 11:52 PM
BRay09
25
Jan 18, 2009 03:13 PM
