A Question for Cookie
Old Aug 14, 2007 | 07:39 PM
  #61
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It was slightly more involved than that , but not really something that I feel needs to be brought back up at this point.
Threads like this are exactly what this forum is about...the sharing of information, but if one tries to use these forums to promote something that is clearly not allowed, then yes, the webmaster takes it seriously.
Old Aug 14, 2007 | 07:51 PM
  #62
Action4478's Avatar
Action4478
I'm confused how the grease gets into the bearing from the area where the tone ring is , or the reluctor (if that is what it is called)Aren't these sealed bearings?.....
Old Aug 14, 2007 | 07:55 PM
  #63
John311t's Avatar
John311t
If im thinking correctly, the tone ring is located inside the "sealed" bearing. If you insert grease there it will get to the "sealed" bearing.
Old Aug 14, 2007 | 07:59 PM
  #64
cookie88's Avatar
cookie88
FTE Emeritus
I'm not positive that it does. However, both of my factory hubs failed within the first 2.5 years I owned the truck. Now, we know that the bearings are sealed from the outside, but I wasn't sure if they were completely sealed from each other inside the housing, so I packed the cavity between the two full of grease. No issues with the hubs in the almost five years since then. One can infer from this information that at least some grease makes it into the bearings....but until one is completely disassembled we won't know for sure.
Old Aug 14, 2007 | 08:04 PM
  #65
John311t's Avatar
John311t
Hmm, maybe a disection for my old bearings is in place. I can check it out on my old ABS wheel bearing. I just gotta make that tool to check if it is getting grease inside the bearing. Ill try it out tommorrow if time premits.
Old Aug 14, 2007 | 08:08 PM
  #66
Action4478's Avatar
Action4478
I have one here I can wreck......
Old Aug 15, 2007 | 12:34 AM
  #67
SpringerPop's Avatar
SpringerPop
I got the nut off once, but the thing's gonna' take some major hammering to get it apart.
Whatever that yellow stuff is, it's tough!
I finally gave up, but only for the time-being.
To quote our Governator, "Ahhhhlll be baaaaack"!
Pop
Old Aug 16, 2007 | 12:43 AM
  #68
wlihntr's Avatar
wlihntr
i think we have to name it........the springerpop
Old Aug 16, 2007 | 02:10 AM
  #69
SpringerPop
How about just a "hub lube adapter", thanks. ;-))
Pop
Old Aug 16, 2007 | 07:50 AM
  #70
yamaguy's Avatar
yamaguy
Ok then it's officially THE SPRINGER HUB LUBE ADAPTER.
Old Aug 16, 2007 | 09:23 AM
  #71
cookie88's Avatar
cookie88
FTE Emeritus
That sounds like a part for a Harley.
Give it an acronym so it fits in a sig line. The SHLA
Old Aug 16, 2007 | 11:46 AM
  #72
thinksnow's Avatar
thinksnow
Please put me down for one please
Old Aug 16, 2007 | 01:27 PM
  #73
fbilly420's Avatar
fbilly420
I am deffinetly wanting one of those "springer hub lube adapter" i am having an issue right now my left wheel bearing is so dry it is squeaking and driving me crazy. PLEASE put me on the list I am willing to donate for your time and will pay for overnite shipping.
Old Aug 16, 2007 | 03:13 PM
  #74
2002f2507.3LPS's Avatar
2002f2507.3LPS
ill take one. .
Old Aug 16, 2007 | 03:43 PM
  #75
jetdoc's Avatar
jetdoc
If it's dry to the point of making noise, the damage is already done.
