A Question for Cookie
Old Aug 12, 2007 | 11:38 PM
  #31
mndiesel's Avatar
mndiesel
anyone have any pics of where these things attach in the hub? Thanks in advance
Old Aug 12, 2007 | 11:39 PM
  #32
SpringerPop's Avatar
SpringerPop
Clux,
No, I only used the dimensions of the old sensor, and the tiny o-ring from it. It's turned out of a 1/2" bolt.
Tex,
The thickness of the o-ring material is .041". Send another email, the first one never arrived, or send it in a FTE-o-gram. ;-))
I'll post a reduced-size photo of the drawing I scrawled together, but at the small size that attachments must be, it likely won't be readable.
Edit: Hey, that came out better than I thought it would.
Edit: If ya' think about it, that o-ring is overkill, and just contributes unnecessarily to the complexity. If I had to do it over again, I'd leave the o-ring groove out.
Here ya' go!
Old Aug 12, 2007 | 11:41 PM
  #33
mndiesel's Avatar
mndiesel
Originally Posted by Texas Outlaw
I could never take money from anyone here for anything. If I can get them made up and I can get enough made up I will give them away.
Scott,
If you get enough I would like one as well. I know you said you could take no money from anyone on here but I don't mind paying for the product or the time you spend making them. Thanks
P.S. I will also pay for shipping. THX
Old Aug 13, 2007 | 01:12 AM
  #34
wlihntr's Avatar
wlihntr
pop, if you or scott or someone could make those to be sold you could make some money!!! i bet dennis at ITP or a number of other places would pick that up. i mean heck if you could greese the front bearnings for $10 or $20 to buy that thing rather than pulling them apart or worse replacing them....that thing is a total winner, i bet just about any one with an SD would buy one!!...someone needs to get it to maket
Old Aug 13, 2007 | 05:22 AM
  #35
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Originally Posted by SpringerPop
Clux,
Tex,
Here ya' go!
What is the OD on the largest diameter, right side of piece? I am thinking a piece of 1/2" material would work perfect.
Also, the angles, those are 45's correct?
Is the 13/64 drill also the tap drill size for the metric zerk fitting?
Is a metric zerk an absolute must? Can it be a standard thread zerk?
Standard dimensioning on the 3 place decimals (+- .002)?
It will work correctly without the o-ring? Just leave that off?
Old Aug 13, 2007 | 05:31 AM
  #36
jtharvey's Avatar
jtharvey
That's a heck of an idea. I would definately like to have something like that (after replacing a bearing last year), but have no way to machine a bolt like that.
Old Aug 13, 2007 | 06:23 AM
  #37
Texas Outlaw
Not a liberal...
Pop.....I already have the answer in regards to the 13/64 drill.
Old Aug 13, 2007 | 06:50 AM
  #38
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
What do i get for being the winner?
Old Aug 13, 2007 | 07:49 AM
  #39
bdrummonds's Avatar
bdrummonds
That and $5 will get you a froo-froo coffee type drink at local starbucks....
Old Aug 13, 2007 | 09:27 AM
  #40
2002f2507.3LPS's Avatar
2002f2507.3LPS
is this for the needle bearing or the main bearing? sorry if this has allready been answered... but i didnt see it.
thanks,
Old Aug 13, 2007 | 09:37 AM
  #41
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I could never take money from anyone here for anything. If I can get them made up and I can get enough made up I will give them away. We are in sweeps month right now at work (last month of the fiscal year) and machine time is very tight but there are some tricks to getting things done sometimes.
I'd like one myself and like others here, would be very happy to cover your beer expenses for this service! I mean, seriously, it's worth AT LEAST the cost of a case!! Please keep us up to date, and I would most definitely look in to patenting that idea and marketing it.
Old Aug 13, 2007 | 10:01 AM
  #42
SpringerPop
Tex,
Yes, the major dimension is 1/2". I turned it from an old 1/2" bolt.
45 degrees is not necessary, any angle will do, I just wanted the size transitions to be smooth.
Any standard zerk will do the trick, and the through-hole and tap should just match whatever you use. I "think" that 1/4-28 is also a zerk thread, and would work just as well. I had metrics, so that's what I used, that's all.
Standard dimensioning tolerances will be just fine. The sizes are what I measured my old sensor to be. The most important of all of them will be the overall length doesn't exceed the .700" in depth down the hole, and the .398" so it will fit into the hole.
The o-ring isn't necessary, and is really "over-kill".
Pop
Old Aug 13, 2007 | 10:45 AM
  #43
Texas Outlaw
Not a liberal...
Thanks, Pop!
I marked up a drawing to reflect the changes and am watching for machine time now.
Old Aug 13, 2007 | 02:25 PM
  #44
rad1026's Avatar
rad1026
I'm bumping this because I am still not sure what bearing is lubricated by greasing through the ABS Sensor hole. Is it the front hub needle bearing?
Old Aug 13, 2007 | 02:45 PM
  #45
UcaN's Avatar
UcaN
Would a newb be eligible to receive one of these..??? I'll pay shipping and donate to your time....
Great idea.. ..
thanks
