1964 F100 door tag decoding
Originally Posted by Horsepowerdan
Hello all. New member here looking to decode the following door tag information from my 1964 F100. Not too sure about the items in red.Thanks.
F10CE56884
WB 114
Color K
Model F100
Body D81
Trans A
Axle 12
Max GVW lbs 5000
135 hp @ 3800 rpm
DSO 23
F10CE56884
WB 114
Color K
Model F100
Body D81
Trans A
Axle 12
Max GVW lbs 5000
135 hp @ 3800 rpm
DSO 23
F10 = F100 2WD
C = 292 2V
E = Mahwah NJ Assembly Plant
56884 (Missing a digit, should be 6, not 5) 1964 serial number range: 445,000-580,000
114 = 114" Wheelbase
K = Bengal Tan
F100 = F100 2WD / 5,000 lbs. GVWR
D = Light Beige Crush Vinyl / Medium Beige Check Stripe Woven Plastic
81 = 81B Custom Cab
A = Ford 3 Speed Manual All Syncro Transmission
12 = Ford 9 Inch Rear Axle / WBG-F-H / 3.89-1 / Non Limited Slip / 3300 lb. Rear Axle Capacity
5000 = 5,000 lbs. GVWR
135 HP @ 3800 RPM
23 = Philadelphia PA Ford District Sales Zone
Thank you very much for the information. You are absolutely correct, I missed a digit in the VIN. It should be 568884 (missed an 8).
The front cab mount on the drivers side is in poor condition and needs to be replaced. I see that I can purchase the floor pan, but I'm having a difficult time locating the replacement cab mount for the drivers side. Can I use/modify the 1965-66 drivers side cab mount?
2-C4TZ-8100155-C .. Cab Mount (Insulator) Lower Front - Lower Rear
Fits ALL 1964/72 F100/350 2WD.
Supplier's may not use these same part numbers.
Regardless, the cab mounts are all the same for 2WD's.
1986F150six
02-13-2017 09:41 AM
Fords & Whalers
10-31-2016 12:19 PM
76f350spercamprspeal
15
02-18-2008 05:14 AM
