Vin Tag Decode
Old Feb 21, 2017 | 08:24 PM
jkenney91's Avatar
jkenney91
Vin Tag Decode
Hi guys!
I have a 1964 F100 that I am restomodding. I will be starting a build thread soon but was wondering if I could get some help with the decode:
F10CK521409
WB: 114
Color: Y
F100
Body: 281
Trans: B
Axle: 12
5000 135 3800 75
Thanks guys! The help is much appreciated!
Old Feb 22, 2017 | 10:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jkenney91
Hi guys!
F10CK521409 / WB: 114 / Color: Y / Model: F100 / Body: 281 / Trans: B / Axle: 12 / Max GVW lbs: 5000 / Cert net HP: 135 / RPM: 3800 / DSO: 75
F10 = F100 2WD
C = 292 2V
K = Kansas City MO Assembly Plant.
521409 = 1964.
114" Wheelbase.
Y = Cannot list exterior color at this time.
F100 2WD .. 5,000 lbs. GVWR
281: 2 = Medium Blue Crush Vinyl & Medium Blue Rib Vinyl / 81 = 81A Standard Cab.
B = Borg Warner 3 Speed Manual with Overdrive.
12 = Ford 9" Rear Axle / 3.89-1 / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
75 = Phoenix AZ Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Feb 22, 2017 | 02:28 PM
jkenney91's Avatar
jkenney91
Thank you very much, NumberDummy! That makes sense that it was ordered from Phoenix since I still have the factory bumper labeled Swift Ford in Yuma, AZ.
I believe the original color was skylight blue since that seems to be the code I found for other years and remnants of the paint are a light blue color. It is now painted a tan-ish white color.
Also, it has a limited slip rear axle now. Could that have been a dealer added option? I am surprised that it came with a non-limited slip.
Thanks again!
Old Feb 22, 2017 | 05:38 PM
jkenney91's Avatar
jkenney91
I just checked and the rear axle is actually a Dana 44, not a 9 inch. Could this limited slip dana 44 be a dealer option or is it swapped on? Either way I was excited to see that!
Old Feb 22, 2017 | 05:57 PM
NumberDummy
Compare the VIN stamped on the Warranty Plate to the VIN on the registration to see if they match.
1963/79: People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
1959/67 F100: Dana 44 with Limited Slip was optional, but if it came with it originally, the first digit of the AXLE code would be a letter.
The 9" with Limited Slip was not available in F100's until 1968.
And, besides the Dana 44, the rear axle with Limited Slip could also be a Dana 60.2 (1963/66) or a Dana 60.3 (1966/67).
Neither of these are a Dana 60, only installed in F250's.
Old Feb 24, 2017 | 06:41 PM
schreyeranna's Avatar
schreyeranna
1966 F-100
Completely new to all of this and just bought a 1966 F-100. It will be my first project truck (project vehicle for that matter) and I am completely overwhelmed with where to even start, but figured knowing a bit more about the truck would help.
If anyone could help decode it would be greatly appreciated!
Old Feb 24, 2017 | 10:54 PM
robbv's Avatar
robbv
just was seeing if anyone could decode this beast i picked up tonight
i think its a f350 but done the year or much else thanks
Old Feb 25, 2017 | 10:18 AM
NumberDummy
F10 = F100 2WD
Y = 352 2V
860390 = 1966.
129" Wheelbase.
COLOR: Blank*
D81: D = Medium Beige Crush Vinyl & Medium Beige Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
17 = Ford 9" Rear Axle / 3.25-1 / 3,300 lbs. Rear Axle Capacity.
172 net HP @ 4,000 RPM
739080:
73 = Salt Lake City UT Ford District Sales Office, where the original selling dealer ordered the truck from.
9080 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
Old Feb 25, 2017 | 10:33 AM
NumberDummy
Originally Posted by robbv
just was seeing if anyone could decode this beast i picked up tonight.
i think its a F350 but done the year or much else thanks.
4 = V8 Engine.
81 = Cab & Chassis.
35 = 350 Series.
32 = 132" Wheelbase.
L = Left Hand Drive.
173080 = 1965 Numerical Sequence of Assembly.
B = 6,100-10,000 lbs. Gross Vehicle Weight Rating.
Old Feb 25, 2017 | 11:18 AM
robbv's Avatar
robbv
awesome thanks for that guys
anyone know the RR engine code
would it be a international MD V8?292
Old Feb 25, 2017 | 11:38 AM
NumberDummy
It's not an IHC engine. It's probably a 292 2V
svolpone
Aug 13, 2014 07:18 PM
62FE4x4
Apr 9, 2012 04:07 AM
broken knuckles
Jul 18, 2011 10:30 AM
davewave649
May 8, 2011 12:52 PM
ford0625
Dec 16, 2009 03:28 AM
