EBP line removal HELP
Old Aug 9, 2007 | 09:13 PM
ztodd377's Avatar
ztodd377
I'm wanting to remove my EBP line to clean it, but for the life of me can't get the stinkin thing undone. Is it normal or reverse thread? Did you guys have to soak it PB Blast or some other kind of rust breaker? If any body has any step by step, stoopid proof instructions on how to get this thing off without f***ing it up, that would be great!
Todd
Old Aug 9, 2007 | 09:20 PM
indebt's Avatar
indebt
check here http://guzzle.rbmicro.com/ebps.html when I did mine I put then wrenches only far apart enough to be able to palm them and squeez them together(hope that makes sense) and muscle it a bit!
Old Aug 9, 2007 | 09:48 PM
ztodd377's Avatar
ztodd377
Talking
Thanks for the link. I've used guzzle's site before and found it super helpful, but didn't even think to look this time. Thanks again.
Old Aug 9, 2007 | 10:11 PM
bdrummonds's Avatar
bdrummonds
Rampage_350 and I just did this last weekend. used the crowsfoot on the sensor, and a open end on the manifold. I had to form a new tube out of brake line, cause when mine came off it had holes in it. It is much eaiser to make a new one when you have another good one to use as a pattern. cleaned out the sensor with brakeclean and a small pick/file. truck runs much better now. idle has smoothed out considerably.
Old Aug 9, 2007 | 11:11 PM
totin_tools's Avatar
totin_tools
Just looked at Guzzles site and I tried it a little different. I took it off at the manifold first and then unscrewed the whole bracket off of the hpop resivor. Seemed a little easier when I did it since I didnt have any crows foot wrenches and stuff. Then when I reinstalled it I left it loose at the bracket until I got it on the manifold. Then tightened it all up. I also had an oil leak at the bracket from when I changed the hpop so this seemed like a way to fix two things at once.
Old Aug 10, 2007 | 09:39 AM
LB_'s Avatar
LB_
Careful when using the crowfoot wrench...mine fell off and ended up inside the waterpump pulley. I had a b***h of a time tring to get it out. I recommend covering the pulley with a rag.
Old Aug 10, 2007 | 09:42 AM
fbilly420's Avatar
fbilly420
i just used a deep chrome socket on the sensor and i worked fine.
Old Aug 10, 2007 | 09:46 AM
99SevenPoint3's Avatar
99SevenPoint3
x's 2 and a wrench to hold the bottom and i would say pb blaster or wd40 is a good thing
Old Aug 10, 2007 | 03:02 PM
ztodd377's Avatar
ztodd377
How did you make a new one out of brake line? Where did you get the brake line?
Old Aug 10, 2007 | 10:24 PM
bdrummonds's Avatar
bdrummonds
Orieleys. 3/16 steel brake line 3'($3.88), reuse the ends off old line, double roll flaring tool, ($9.00), tubing bender($10.00).
when you get the line it will be pre flared on both ends and have male compression fittings. cut off one of the flares and slide off the comp. fittings. slide one of your old female fittings onto new line. Start bending, this works better if your old tube is not falling apart, and can use it as a pattern.
slide the other female fitting on and flare that end and put back on truck.
Old Aug 17, 2007 | 04:31 PM
f350rebel's Avatar
f350rebel
i'm going to try it this way because when i tried it the way the site said i couldnt get the line loose up by the sensor no way no how.... I'm a 6'6 240lb college athlete so i know i'm not weak, but damn that thing was tough
Old Aug 17, 2007 | 04:36 PM
c00nhunterjoe's Avatar
c00nhunterjoe
let the truck get hot first, it will break loose easy with the crows foot, works wonders on broken manifold bolts as well, i have only ever had to use a torch once in all my years of broken bolts in exhasut manifolds and tubes....heat is the key
Old Aug 17, 2007 | 04:44 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Useful tip!
When you are using the crow's foot take a small piece of duct tape and secure the crow's foot to the extension. If the crow's foot falls off while you are working with it and it falls down into a motor cavity it is tough to retrieve.
I know from experience.
galaxie521
Bronco II
May 3, 2013 11:58 PM
gb'sfx4
Dec 23, 2010 06:37 PM
todd f.
Aug 18, 2010 06:05 PM
natew
Jan 4, 2010 11:16 PM
