Bronco II Ford Bronco II
bronco ii brake problem
Old May 2, 2013 | 03:52 PM
galaxie521's Avatar
galaxie521
I recently picked up an 89 bronco ii and I am having a problem with the brakes. When i step on the brakes the pedal is solid and has almost no brakes. not sure what to do. any help would be great. Thanks Todd
Old May 3, 2013 | 11:28 AM
Josh S's Avatar
Josh S
Hey, I was hoping somebody with more experience might come forward to help you out but there's not a lot of action in the B2 forum unfortunately. I'm more of your typical do-it-yourselfer but will give it my best.
Could you clarify what you mean by the pedal is hard? They do stop a little harder than most vehicles (single cylinder brake calipers rather than the twin cylinder standard nowdays) and that did take some getting used to for me. But if you're saying there's basically no brakes then that's definately not normal.
You've done the initial things like checking the fluid and looking at the pads/rotors & shoes/drums?
Old May 3, 2013 | 05:21 PM
f5fordgirl's Avatar
f5fordgirl
Your brake booster may be bad, unplug the vacum hose and plug it, then start the engine and see if the feeling on the petal changes. If not, first make sure you are getting vac at the valve going into the booster. If you do, then most likely the booster is shot. Or you could also have a line pinched going from the master cyl to the centering valve on the frame.A way to check that is, open one of the wheel cyl bleeder valves, and have somebody push the brake petal down an see if fluid comes out.
Old May 3, 2013 | 09:03 PM
PetesPonies's Avatar
PetesPonies
Yep, agree, sounds like the booster.
Old May 3, 2013 | 11:58 PM
galaxie521's Avatar
galaxie521
Thanks for the info. I will check a few things out tomorrow and check back. Thanks Todd
truckfella
Modular V10 (6.8l)
17
Mar 16, 2020 11:59 AM
joemajesty
Jul 28, 2010 04:12 PM
SilverBronco
Jan 4, 2009 06:13 PM
rmalottwtes30
Apr 17, 2008 10:28 PM
jbulson
Sep 8, 2002 07:53 AM
