intercooler vendor question
Old Aug 14, 2007 | 01:45 PM
  #46
tjbeggs's Avatar
tjbeggs
yes if you get the banks twin ram and the banks turbo outlet pipe, 7.3 superduty pipes and a 6.0 cooler you can make it work but the pipe still need some modding. the driverside pipe is flipped end for end and 4 or so inch added to the top end near the turbo. the passenger side pipe is the one that takes the most fab work. I built mine from one 7.3 superduty drivers side and passenger side pipe frankenstined together.
you are also correct about the Boyer kit. Its doesn't sound like the mounted brackets are included. the biggest hurdles in the IC install is the y-pipe and fitting the cooler its self. tubes took me no longer than 2 hours and 1 hours was pure welding. didn't take long to mock up at all. there are many different ways to come up with all your parts. it depends on how much time, skill and money you have as to which way you go.
Old Aug 14, 2007 | 01:51 PM
  #47
Neal 97 250's Avatar
Neal 97 250
I thought 7.3 pipes were 7.3 pipes and that was it. I guess they can't be taken fron an '00 and just put on a '97 without modding them, Right?
Old Aug 14, 2007 | 02:35 PM
  #48
tjbeggs's Avatar
tjbeggs
nope superduty pipes need to be modded no matter what. you can see my webshots for what I did to the superduty pipes I had.
Old Aug 14, 2007 | 03:34 PM
  #49
RocknXJ's Avatar
RocknXJ
I'm about to order the Banks pipe kit, probably from Boyer for $580. The Boyer kit includes the y pipe/Twin Ram, turbo outlet, IC tubes, four boots and eight clamps. No brackets. The Banks kit includes all kinds of brackets for the IC, trans cooler, rubber air dams, etc, etc., stuff we don't really need to put in another cooler. Banks price for just the hard parts is $194 for the Twin Ram, $112 for the turbo outlet, and $94 each for the tubes, total $494. So, Boyer is getting $86 for the 4 boots and 8 clamps which sounds reasonable.
Old Aug 14, 2007 | 03:44 PM
  #50
Neal 97 250
Oh thanx for breaking it down. I was going to call them tomorrow and ask.
Old Aug 14, 2007 | 11:54 PM
  #51
Pest007's Avatar
Pest007
I saved a few bucks by not getting all the stuff from banks, and just the nessisary hardware, I had the hookups at a Frieghtliner dealership so I got discounts on all the clamps and other related hardware, just got pipes and had to get banks boots too, damn semi's don't use 3" intake stuff, mostly 4" or 5"!!!
Old Aug 15, 2007 | 01:10 AM
  #52
gt8684's Avatar
gt8684
speaking of the banks intercooler kit, and the 6.0 intercooler.... which is larger? i would assume the banks because thats what they say, but has anyone seen the 6.0 intercooler and banks intercooler (7.3l) together to compare?
Old Aug 15, 2007 | 08:05 AM
  #53
Neal 97 250
How did you mount the intercooler. Did you make your own brackets?
Old Aug 15, 2007 | 08:48 AM
  #54
Pest007's Avatar
Pest007
Yes I made my own brackets, just used some 1" x 1/8thick flat steel for the top supports using some old rubber shock bushings I had, and then welded up some pieces using the 1" x 1/8thick flats and 1"x1" angle iron mounted to the body, not the frame. I've seen where people mount to the frame, but this is not a good idea since the body is mounted on isolators for a reason!!
Old Aug 15, 2007 | 05:33 PM
  #55
Neal 97 250
Thanx I'll be sure to have some of that onhand when I get started. It is nice to know what you need before you get in there and have to go get it. Anything else I should have just in case?
Old Aug 15, 2007 | 10:48 PM
  #56
c00nhunterjoe's Avatar
c00nhunterjoe
if you are willing to make them your self i have boxes and boxes of the turbo tubes and clamps, i used the y-pipe off the pre june 99's, almost direct bolt on.
Old Aug 16, 2007 | 04:57 PM
  #57
Neal 97 250
I will keep that in mind also. Thanx c00n and welcome back. Have fun? which beach did you go to? Almost kinda missed ya in a manly kinda way though.
Old Aug 16, 2007 | 05:01 PM
  #58
c00nhunterjoe
lol, awww i went to ocean city maryland and burnt my face and tops of my feet, never thought of sunscreen on the feet
Old Aug 16, 2007 | 05:02 PM
  #59
Neal 97 250
That'll get ya every time.
Old Aug 16, 2007 | 08:04 PM
  #60
c00nhunterjoe
most definatly did
