Oil cooler, needed?
Old Aug 1, 2007 | 08:59 PM
Flea's Avatar
Flea
Oil cooler, needed?
I was thinking about installing a oil bypass filter and then t-ing into the line and installing an oil cooler?
Has anyone done this and would it be beneficial or a waste?
Old Aug 1, 2007 | 09:04 PM
Suber's Avatar
Suber
I have seen many of the write-ups for them, but have not done one. IMO it is a non-essential item , unless you are itching to burn money. You could piece it together yourself and save some coin as opposed to buying it in the complete kit.
Old Aug 1, 2007 | 09:15 PM
Flea's Avatar
Flea
Well I have a tranny cooler sitting around and I was thinking about what I could use it for.
I was wondering if I could get my hands on the kit for the bypass filter but not do one. Or, at least yet.
I wonder what the improvements would be?
Old Aug 1, 2007 | 10:15 PM
Suber's Avatar
Suber
Is the Tru-cool not cutting it?
Old Aug 1, 2007 | 10:17 PM
tjbeggs's Avatar
tjbeggs
Do the filter leave out the cooler. I prefer a Frantz or Motor Guard filter over the more exspensive units. they require more frequent fitler changes but they also don't cost you $20 for a filter element each time either.
here is a link to my install info and pics
http://good-times.webshots.com/album/559095173QctrNV
here is a good forum to read about all sorts of bypass filtering
http://theoildrop.server101.com/foru...=0&Board=UBB36
Old Aug 1, 2007 | 10:22 PM
Flea's Avatar
Flea
No the truCool did the job. Old tube cooler is going away.
Why would you leave out the cooler? Is it bad for the truck or not necessary in the least?
Old Aug 1, 2007 | 10:30 PM
tjbeggs's Avatar
tjbeggs
Just so I am clear we are talking engine oil right?
If so the reason I would not cool the engine oil any more is first it already has a factory oil cooler that does a good job and secondly it's an opportunity to leak.
also adding a bypass filter will also cause some cooling affect.
Old Aug 1, 2007 | 10:46 PM
powerstroked162's Avatar
powerstroked162
Ditto Tim
Cowboy Steve
Old Aug 2, 2007 | 01:46 AM
Flea's Avatar
Flea
yes. I didn't know their was a cooler already in place.
Old Aug 2, 2007 | 05:50 AM
tjbeggs's Avatar
tjbeggs
Yes the oil cooler is a oil to coolant cooler. The housing the oil filter screws onto is one end of the cooler and the 3 inch tube that goes toward the front of the engine is the cooler.
Old Aug 2, 2007 | 08:00 AM
Suber's Avatar
Suber
Wow glad that was cleared up, I must have been REALLY tired last night as I read all this to be you adding another TRANNY cooler with an in-line filter as well. Anyway
Lance Amatulli
Feb 7, 2015 06:43 PM
pa-12
Mar 11, 2014 11:40 PM
BobbyB
Oct 13, 2011 10:54 PM
vlietracer64
Nov 3, 2010 10:35 PM
billfishnut
23
Jan 3, 2010 09:07 AM
