Where to install Oil Temp sensor
Old Nov 2, 2010 | 10:18 PM
vlietracer64's Avatar
vlietracer64
Looking for a spot to install an isspro engine oil temp sensor, while doing my arp head studs and oil cooler upgrade. Can i use the oil test port on the front of the oil cooler housing???
Thanks,
Peter
Old Nov 3, 2010 | 04:56 AM
Nice Work Truck's Avatar
Nice Work Truck
I would like to know also?
Old Nov 3, 2010 | 07:37 AM
texans's Avatar
texans
You can use the test port. Me personaly I got a billit oil filter cap that was taped for a sender. Works good this way and much easier I think. Many on here do it this way.
Old Nov 3, 2010 | 01:01 PM
da-bees's Avatar
da-bees
More important than where a sensor can be mounted is wherether the readings recieved from that location matches readings from obd port. Has anyone made the compairison?
Old Nov 3, 2010 | 07:00 PM
joe blow's Avatar
joe blow
The reading is innacurate from the cap....or so I have heard. I did it a different way and have good results but without a second reference I will never know the accuracy of my install, but after driving it for 1k miles and pulling trailers it seems to be within the 5* or even with ECT's...here is the link:
https://www.ford-trucks.com/forums/9...ml#post9278900
or you can buy a scangaugeII and be done with it...which is what I should have done but instead I opted for four more gauges.
Old Nov 3, 2010 | 10:35 PM
vlietracer64
Anyone know the thread size and type for the oil test port on the oil cooler housing
JamesMcMn
Oct 17, 2016 10:47 PM
justcruzin125
Sep 7, 2016 01:06 PM
wisevoss
Jan 29, 2014 04:51 PM
shuttlevalve
Jun 16, 2010 06:35 PM
yz400f
Dec 1, 2009 02:08 PM
