Sponsored by: Auxito
check engine light blinks?
Old Jul 22, 2007 | 09:20 PM
98infinity's Avatar
98infinity
What does it mean when the check engine light blinks? and then stays on and then blinks, truck is running rough like its going to stall but doesnt!
Old Jul 22, 2007 | 10:02 PM
galaxie641's Avatar
galaxie641
Blinking is usually an alert that the problem is rather immediate, when they stay on steady it is usually just an emissions issue or slight misfire. Either way it needs to have the codes pulled ASAP and I wouldn't drive it a lot until you find out what the codes are.
Old Jul 23, 2007 | 12:03 AM
Bluegrass 7's Avatar
Bluegrass 7
A cylinder is missfiring. Raw fuel is reaching the cats and overheating them.
Get the fault fixed now!
Old Jul 23, 2007 | 01:54 AM
SchwinnTruck's Avatar
SchwinnTruck
Yah, you can clog them up or worst case start a fire. DO NOT continue to drive your truck in this condition.
One likely cause is spark plugs or ignition coils going bad. Had that happen to my truck, a coil went bad, resulted in that cylinder not firing, very characteristic sort of 'shuddering'. Cost $300 to get fixed, but it's a lot cheaper if you can do it yourself, new coil runs around $60-$80 - wish I'd been on these forums when it happened, because then I would have fixed it on my own. If you do want to do it on your own then get the codes read at Autozone or some such place, and look here for more info on how to do the fix.
P.S. For some reason the coils often fail at the same time - a month after the first one a second went bad, so be on the lookout for that if a bad coil turns out to be your problem.
Old Jul 23, 2007 | 02:47 AM
LxMan1's Avatar
LxMan1
Summit racing has Accel cops' for $30 a piece.
It flashes when it is seeing a fault. If it sees it long enough, it will stay on solid. Have it scanned and we'll guide you in the right direction on getting it fixed.
Old Jul 23, 2007 | 06:47 AM
98infinity's Avatar
98infinity
if it is the cops or the plugs should I just get them all changed? that would be like 1000 bucks!
Old Jul 23, 2007 | 08:59 AM
SchwinnTruck
No, I think the code should tell you which coil is bad if it is a cop issue.
Old Jul 23, 2007 | 10:32 AM
98infinity's Avatar
98infinity
yep it did number 6 cyl. cop toast...
Old Jul 23, 2007 | 11:16 AM
98infinity's Avatar
98infinity
will stock cops off a 99-04 lightning work for my truck? 03 5.4L auto?
Old Jul 24, 2007 | 08:38 AM
SchwinnTruck
Don't know off the top of my head, but someone at a parts store should be able to tell you if they use the same replacement part - and if they do, then yeah they should work.
bertram38
Sep 2, 2012 05:10 PM
plowguy
Jan 6, 2006 06:23 AM
searsk
Nov 3, 2005 07:33 AM
merc460
Sep 9, 2002 04:15 PM
