blinking lights
Old Sep 2, 2002 | 06:08 PM
merc460's Avatar
merc460
blinking lights
Old Sep 7, 2002 | 02:50 PM
65pro's Avatar
65pro
blinking lights
My daughter and I are restoring a 65 Ford Fl00. We have replaced all the wiring harnesses under the hood along with blinker switch, headlight switch and dimmer switch. When we put on the blinkers or headlights and parking lights including dash lights, they all blink. If we turn off headlights and parking lights, dash lights still blink when signal light is turned on in either direction. Truck has 4-way flashers that seem to work well. Can anybody help? Daughter would like to drive before the body rusts again!
Old Sep 7, 2002 | 06:30 PM
mwc4275's Avatar
mwc4275
blinking lights
I had a similar problem when I started working on my 65' F-250. Try running a ground wire from your driver's side tailight, to the frame. Hope this helps.
Old Sep 8, 2002 | 05:34 AM
Jimbare's Avatar
Jimbare
all alone in the world
blinking lights
make sure all the ground straps are in place from the batt to the block and body, the block to the frame, the engine to the firewall, and from the frame to the bed.
Old Sep 9, 2002 | 04:15 PM
65pro's Avatar
65pro
blinking lights
thanks for the info. we will give it a try
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
