Wiring a DPDT switch
Old Jul 18, 2007 | 03:54 PM
WilliesSD250's Avatar
WilliesSD250
anyone help me wire up a DPDT switch?? for the life of me I can't figure it out and the switch doesn't have any markings to let me know what terminal is what. Theres 6 connections on the back of the switch. Thanks.
Old Jul 18, 2007 | 04:10 PM
fmc400's Avatar
fmc400
MSEE
If there isn't anything written on it, your best bet is to use a DMM set to continuity and see what connections beep when probed. Two of the connections will be the common for each internal switch. Each common will short to one connection in one position and the other connection in the other position. The same will apply for the other set (1 common plus 2 connections for each of the 2 sides for a total of 6 connections).
Old Jul 18, 2007 | 06:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
What is it you are trying to do?
Old Jul 24, 2007 | 12:54 PM
lsrx101's Avatar
lsrx101
Lets see if i can do this:
out X X out
In X X in
out X X out
The Xs are the terminals on the rear of the switch.. The center "in" terminals are connected to one "out" terminal in the column for each switch posioion. Think of it as 2 switches side by side. The terminals never interconnect from left to right.
Here's a symbol that may make it clearer:
http://en.wikipedia.org/wiki/ImagePDT-symbol.svg
The 2 terminals on the right side are the center terminals on your switch.
Old Jul 27, 2007 | 07:19 PM
mhg's Avatar
mhg
ok Ill give it a try
this is two seperate switches as noted above
side one X O X
X being your load side and O is your feed in the middle
switch is thrown to one side power goes from the center pole to
the outside pole and when you flip the switch to the opposite
side power goes from the center pole to the other out side pole
now add another switch beside that one and you DPDT
you must have power to both center poles to have both sides work
the two sides are completly independant of each other
and to add a little more to the mix you can get these with a center off
position also
Old Jul 27, 2007 | 07:29 PM
lsrx101's Avatar
lsrx101
side one X O X
position also
Kinda hard to describe in text, ain't it? It's one of those things that, once you understand it, is really simple.
Once you understand a DPDT switch, power windows are a breeze.
Old Jul 28, 2007 | 04:59 PM
jimlj's Avatar
jimlj
A normal, off the shelf DPDT switch IS off in the center position. If mounted vertically, on the vast majority of the switches I have worked with center pole is making contact with the bottom pole (same side of switch) when the switch handle is in the up position., the center pole is making contact with the top pole when the switch handle is in the down position
Old Jul 31, 2007 | 08:20 PM
mhg's Avatar
mhg
yes , but is doable
they come in a varity of throws
on no center on
on center off on
spring loaded center off as in window control switch
Old Aug 1, 2007 | 11:18 PM
WilliesSD250
Thanks for the help guys. I was wiring up my nav lights and anchor light on a boat I had bought. Was redoing the lights, bilge pump, ect. and installing new switches too. The light switch was what was fretting me, but after testing the switch with a multimeter (which I went down to Lowe's and bought it made the wiring much more simplier......
Thanks for all the help. FISH ON!!
Robert6401
15
Jun 26, 2009 04:59 PM
dnvoss
Jun 11, 2005 07:14 AM
westval
Jun 24, 2004 08:49 AM
weldman
Electrical Systems/Wiring
May 22, 2001 08:23 PM
weldman
Mar 30, 2001 11:29 PM
