94 Bronco overhead console tempsensor location
Old Aug 1, 2007 | 08:08 PM
lostin90s's Avatar
lostin90s
I buying a 94 EB bronco over ahead console and have a couple questions .
I'm putting it in a 94 F150
1 Where is temp sensor for it Located?
It comes with all wiring from cab out and the auto dimmer mirror. Is it on that harness?
2. I know there will be a 12v wire for temp system and auto dimmer mirror ,
A light curciut wire ,and ground .
What else is there?
I worked on one years ago and just can't remember . These are a simple console there is no MPG ETc in it. Just temp and lights. Thanks
Any reply and and idea will get a ata boy. Thanks
Old Aug 1, 2007 | 08:44 PM
lostin90s's Avatar
lostin90s
If its behind the driver side head light ( I was told it was there)what might it look like ?
Old Aug 2, 2007 | 11:23 AM
Franklin2's Avatar
Franklin2
I have a 95 manual, and I see it there in the picture, but you can really tell what it looks like. It looks like part of the harness just deadends with a plug, and the sensor plugs into it. In my manual it shows it behind the headlight area, and a little toward the radiator.
The wire going into the cab is a darkblue/yellow, and the other wire is a lightblue/orange which turns into a black and goes to ground.
Old Aug 2, 2007 | 06:13 PM
lostin90s's Avatar
lostin90s
Thanks
Guess what I stoped to ask the 35 broncos (no kidding 35 aof em) a sitting at guy up the road . He walks me around back garage and the sits a EB rust bucket with console and everything. Took me 3 hrs to remove trace all wires . I would have never look behind ligth but you guys rock . And the best part is I just swapped him some part Maybe $30 buck . And I'm sure I got everything.
seagiant
Jan 22, 2017 05:39 PM
ligito
Nov 8, 2015 11:31 PM
uscrpick
1978 - 1996 Big Bronco
May 31, 2010 06:40 PM
myself
Mar 18, 2007 01:59 PM
tyger25
Mar 31, 2003 11:12 PM
