Power steering issue
Old Jul 17, 2007 | 09:19 PM
86stepsideF150's Avatar
86stepsideF150
You may have seen my other thread about the engine performance. Here's another problem that needs attention. My power steering will whine all day long. I topped off the fluid, it was a little low, but it whines just the same. It's been a few days since I topped off the fluid, and there is no leak, or noticable leak anyways. Is it the power steering pump? Any advice is appreciated, thanks.
Old Jul 17, 2007 | 09:28 PM
Franklin2's Avatar
Franklin2
Most later Fords I have been around have a whiny power steering system. It's caused by air in the system, and the dealer has a vacuum thing they can put on it to get all the air out, but it's not easy. Just make sure your suction line to the pump is in good shape, or it will suck air into the system.
Old Jul 17, 2007 | 09:46 PM
86stepsideF150
Am I damaging the system by driving it like this? It sounds awful.
Old Jul 18, 2007 | 08:30 AM
Franklin2's Avatar
Franklin2
No, it's just aggravating. Take the cap off the pump, and run the steering full left to right with the engine running a couple of times and see if that helps, and like I said, make sure the suction line does not have a small leak.
Old Jul 18, 2007 | 05:39 PM
86stepsideF150
Is that just a hose that goes to the pump?
Old Jul 18, 2007 | 08:25 PM
86stepsideF150
There's a hose that goes to the pump reservoir, I assume this is what you're talking about. Well, it, along with the pump + reservoir are coated with this black ****. It guess it's leaking.
Old Jul 18, 2007 | 09:52 PM
netscaner's Avatar
netscaner
I had a guy tell me that he was told to add about an ounce or two of regular STP oil treatment to the fluid and it fixes the noisey old fords. Said he had done it a year earlier and that all was fine ever since.
Also, there was recently a thread in the 1987-1996 forum just above this one concerning someone finding a certain pump (Non Ford) at I believe Advanced Auto which fixes this problem.
Old Jul 18, 2007 | 10:52 PM
doctorolds's Avatar
doctorolds
Mine does a bit of whining also. Try this link it should help, I have not flushed mine yet. https://www.ford-trucks.com/forums/6...ring-pump.html
Old Jul 22, 2007 | 12:33 AM
86stepsideF150
Thanks guys. Hopefully i'll figure it out.
cory5517
Dec 29, 2024 10:51 AM
grip1968
Apr 30, 2012 09:26 PM
clintusaf
26
Nov 28, 2010 08:13 PM
oldbeater
Sep 16, 2008 03:09 PM
