Power steering issue
Old May 30, 2013 | 08:16 AM
cory5517's Avatar
cory5517
Well my pressure line blew out of my power steering pump yesterday and I replaced it. I topped off my power steering with Mercon 5 transmission fluid and its still whining when I turn the wheel. Have I missed something or did I damage my power steering pump?
Old May 30, 2013 | 10:08 AM
cory5517's Avatar
cory5517
How long does it take for the transmission fluid to cycle thru the hydroboost system?
Old May 30, 2013 | 10:14 AM
Tugly's Avatar
Tugly
Several range-of-movement turns should help to clear the bubbles, but it's not instant. The pump is over a decade old... I replaced mine.
Old May 30, 2013 | 10:33 AM
cps's Avatar
cps
Replace it if it is old. Flush and fill with synth tranny fluid and you should be good to go.
Old May 30, 2013 | 11:09 AM
cory5517's Avatar
cory5517
Yeah as far as I know the power steering pump is factory so ill go ahead and replace it. While I'm at it ill flush system as well, thanks guys
Old Dec 28, 2024 | 11:53 AM
tommustangii's Avatar
tommustangii
5th Gear
Power steering 99.5 - 2003
I've been battling ps problems for years I have a 99 f350 SD replaced pumps, steering boxes, hydroboost, ball joints tie rod ends, even read how to bleed the system I've been a auto tec for 40 years and I've never seen anything like these trucks, I even removed the pressure valve in the pump and raised the pressure I can dead head it and get over 3000 psi, but it still doesn't help the steering, the tires are Yokohama Geolandar A/T G015 LT 315/75R16 Load E 10 Ply AT All Terrain and some threads say that you just have to live with it, so does anyone have a good solution to help it without replacing everything with aftermarket parts
Tom
Old Dec 29, 2024 | 10:51 AM
Kwikkordead's Avatar
Kwikkordead
Tom
Start a new thread instead of resurrecting a 12 year old one and you'll get a better response.
Listor
May 18, 2019 10:50 AM
cory5517
Jan 14, 2012 03:13 PM
snookerfist
Dec 9, 2006 07:17 PM
senseidanf
Aerostar
Jul 25, 2005 02:55 AM
70T351W
May 30, 2005 09:17 PM
