Throttle linkage
Old Jul 16, 2007 | 04:36 PM
tip49's Avatar
tip49
Throttle linkage
Does anyone have a picture showing the stock throttle linkage for 48-50 F1 on the firewall connected to the carb ?
I am thinking about reverting to using the stock gas pedal, and linkage connected to the throttle body of my '90 5.0L and would like to see how it positions on the firewall.
Tom
Old Jul 16, 2007 | 06:43 PM
COM49F1's Avatar
COM49F1
Tom
look in my gallery geting started the last picture has the fire wall with the linkage there hope that helps
Tom
Old Jul 16, 2007 | 06:45 PM
COM49F1's Avatar
COM49F1
Tom
I have a larger picture that I can email if you want it you can see the linkage better in it
Tom
Old Jul 16, 2007 | 10:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I don't think it will work for you; it goes to the right (passenger) side of the engine and pulls rearwards. Isn't your throttle body facing to the passenger side?
Old Jul 17, 2007 | 05:42 AM
49willard's Avatar
49willard
Not being familiar with the throttle body setup, do you need to pull from the passengers side to advance the throttle? If you do I may have what you need. I modified an original V8 linkage to use with a 600 Edlebrock that i am not going to use.
Old Jul 17, 2007 | 01:22 PM
tip49's Avatar
tip49
Throttle linkage
Thank you for the responses; my EFI linkage is driver's side; but looking at picture I should be able to modify the stock linkage to position it to the driver rather than passenger side. I'll look into it when I get home this weekend.
Tom
51f1truck
Nov 9, 2020 08:47 AM
hivolt5.0
Apr 10, 2009 02:29 PM
tip49
Sep 20, 2007 12:56 PM
tip49
Oct 7, 2006 10:15 PM
tip49
Apr 14, 2006 09:34 PM
