Throttle Linkage
Old Apr 13, 2006 | 10:08 PM
tip49's Avatar
tip49
Throttle Linkage
I am in the process of connecting my throttle linkage in my 50 F1; using 1990 5.0L EFI. I need to shorten throttle linkage and am considering using the stock pedal/accelerator linkage instead of hanging pedal. Anyone done this ?
Tom
Old Apr 13, 2006 | 10:15 PM
53fatfndr's Avatar
53fatfndr
Have you considered a throttle cable from Lokar? That would probably be the easiest route, and it is simple. I went this route on my '53.
Old Apr 14, 2006 | 12:08 AM
fiftyfourdf100's Avatar
fiftyfourdf100
Like 53fatfndr said....Lokar. Thats what I used on my truck, except I used their billet pedal too, I have their throttle cable and kickdown cable for my AOD. Pretty easy, I just got done fabricating a new throttle/kickdown braket to mount on my manifold for it, that was the only problem I had.
Old Apr 14, 2006 | 08:56 PM
tip49's Avatar
tip49
Lokar cable
My understanding is that the Lokar throttle linkage comes in standard sizes; the reason I am looking for linkage is that the 1990 CV cable is about 2" too long. Does Lokar customize the length, wil I have to replace the kick down as well ?
Tom
Old Apr 14, 2006 | 09:27 PM
sdetweil's Avatar
sdetweil
Tom
The Lokar cables are you cut to fit. Throttle and Kickdown.
Sam
Old Apr 14, 2006 | 09:34 PM
DonMckay's Avatar
DonMckay
How much stuff did you get with the 302?
Does the kickdown seem like it will work?
How much short is flathead throttle linkage?
Are you around next week maybe we can get together and look it over?
Don
hivolt5.0
Apr 10, 2009 02:29 PM
tip49
Sep 20, 2007 12:56 PM
tip49
Jul 17, 2007 01:22 PM
tip49
Jul 12, 2007 07:43 PM
tip49
Oct 7, 2006 10:15 PM
