Calling all arms...
Old Jul 23, 2007 | 04:34 PM
  #76
AnOldDog's Avatar
AnOldDog
Originally Posted by fastmover
Thanks to AJ, Chet, and Dan for teaching me about differential, transfer case, and transmission lubrication. Now I need to do somethings to my truck.
I may have come up with a pseudo-scientific explanation of why we should use diesel rated oils, with additional zinc, in engines with flat tappets even after break in. Zinc is used for galvanizing iron and steel providing a protective coating.
http://en.wikipedia.org/wiki/Galvanization
Without it, the steel may be unprotected from flat tappet abrasion.
Old Jul 23, 2007 | 05:09 PM
  #77
3Mike6's Avatar
3Mike6
You guys must have been talking about flat cams and Karls engine?
Karl, I don't recall, but did your cam go flat too?
Old Jul 23, 2007 | 05:33 PM
  #78
fastmover's Avatar
fastmover
Yes it did. I got a better cam out of it.
Old Jul 23, 2007 | 07:47 PM
  #79
TigerDan's Avatar
TigerDan
I talked to the guy at the tranny shop today and showed him the tranny. He said it's one of his, it was rebuilt about 4 years ago and ther truck has been sitting for about the last 3 so it's got pretty low miles since the rebuild. He said he could swap all the internals into the correct case for 200 bucks if we supply the case, and 80 bucks more if he supplies it. For another 300 he could get us a special heavy-duty hand-brazed converter. He recommended changing the valve body as well since the springs that control the shift points are softer for the diesel, so that it shifts at lower RPM.
At this point I think we should look into the guy that Clint mentioned about working on the tranny for us. If that doesn't pan out, I know a guy who does auto tranny stuff on the side who could maybe do it for us cheaper. He's in So. Cal. on vacation right now but will be back Friday so I can contact him then.
Old Jul 23, 2007 | 08:32 PM
  #80
WillyB's Avatar
WillyB
$200 is fair, cheaper is better. I am told it is not much more labor involved to overhaul the tranny as to swap cases. But for a few dollars more I would go with the guy who already knows the tranny. Will the case we have at Mike's work?
Also, the different shift kit is going to be needed - we need to push the engine beyound 3k RPM, which is where the diesels run. Or can we use the kit from the tranny at Mikes?
I am in favor of taking up a collection and getting it done! What do you guys think?
Old Jul 23, 2007 | 08:34 PM
  #81
AnOldDog's Avatar
AnOldDog
You know that I'm in. Just let me know.
Old Jul 23, 2007 | 08:39 PM
  #82
fastmover's Avatar
fastmover
I am willing to pony up some money for it. If we find someone cheaper somewhere else in the state, we (probably Dan) will have to haul transmission parts all over the state to get it fixed, then haul it back up to Dan's. That can cost us lots in gas and time. I say we go with the guy in Dan's neighborhood. (This is coming from a guy who just tried driving a truck back from Montana and then shipping the broken engine to Billings and back.)
Tell me who to send a check to.
kgs
Old Jul 23, 2007 | 09:07 PM
  #83
WillyB's Avatar
WillyB
Mike is the one handling the money - send it to him. He would rather get the money using PayPal - it keeps his wife from getting confused. Perhaps he can post directions and names again.
I can go $150, and I expect we will need around $400. Should we plan on a new torque converter too?
Also, lets let Dan pick the shop - if he trusts his friend he may choose to go with him.
Old Jul 23, 2007 | 09:36 PM
  #84
Mecinoid's Avatar
Mecinoid
Let me first request forgiveness for the high usage of bandwidth here.
But, I want to tell a short story.....
Here are the pictures from this weekend:
The Shop -
Proposed Lift
Actual lift at this point - Rear end Installed
Another angle of the rear end -
One more shot of the rear end / spring for good luck -
Old Jul 23, 2007 | 09:39 PM
  #85
Mecinoid's Avatar
Mecinoid
Mike working on the rear end -
Dan & Mike figuring the front end out -
Karl pressure washing -
Dan with the welder -
Old Jul 23, 2007 | 09:43 PM
  #86
nevrenufhp's Avatar
nevrenufhp
That last one with Dan on the welder should be printed and saved, it's a good one!
Those tires & rims...are they going to be 33-12.50-(15,16, or 16.5)?
Old Jul 23, 2007 | 09:44 PM
  #87
Mecinoid's Avatar
Mecinoid
AJ at his best ....... Napping -
And here is what you guys missed out on the State Park Sunday -
The next time we'll have to plan it so that we can get this site #31 for our crew and a boat ride ....
Old Jul 23, 2007 | 09:54 PM
  #88
Mecinoid's Avatar
Mecinoid
Oh, I missed a couple that I wanted to show.....
Front end painted -
Engine Trial fitment -
These are only a sample of the picts believe it or not. I'll make a CD if someone wants to load into a gallery .... Dan?
Old Jul 23, 2007 | 09:59 PM
  #89
TigerDan's Avatar
TigerDan
Great pics AJ! (Except for the ones with me in them of course...how come I look like I've got some gas backed up in that last one...?)
Dale, the tires are 16.5's
Old Jul 23, 2007 | 10:01 PM
  #90
AnOldDog's Avatar
AnOldDog
Delete this one. AJ answered my request before I knew I had a request.
