Yes you can. Biodiesel with except to really cold weather can be run in any diesel unmodified. Just can't run it straight during the winter months or it gels.
you may need to clean your fuel filter a few times the first few months as I have heard the soy diesel will losen sediment deposits in your fuel system
Actually WVO is not bio-diesel.
Bio-deisel is a mixture of veggie and methanol and the process of transferication is mixed with diesel or not.
WVO(Waste veggie oil can be used with diesel to make bio-diesel
Or
WVO can be burned straight while starting up on diesel or biodiesel.
Get it hot then switch over to WVO. In this case all you do is filter the WVO out of restauraunts or anyone who dumps their veggie and then filter and filter and raise the temp and then you can use it.
Rudolph Diesel invented the diesel motor to run off of peanut oil.
His "rivals" came up with a petro based fuel which they called diesel after him.
This was in the turn of the century when petro. was just coming about.
