Adding Posi/limited slip 95 f250 - Ford Truck Enthusiasts Forums
Old 02-22-2015, 03:43 PM
87thhunter
87thhunter is offline
87thhunter is starting off with a positive reputation.
Okay i tow ALOT thats basicly what the truck is for
95 f250 5.8l 4x4 4.10 HD axle
Ive pulled full gravity wagons of soy beans at 25-26k pounds - slow but it does it. Its a farm truck - some trailer towing
Anyways im sick of getting stuck in 2 wheel drive in literly 2inchs of mud get out and lock the front hubs and then pull out
What is the best "cheapest" solution to add posi/limited slip - All i want is not to have to lock the hubs every time i have to drive into a slightly wet field.
Old 02-22-2015, 03:53 PM
MI02SVT
MI02SVT is offline
MI02SVT is starting off with a positive reputation.
I would just leave the hubs locked in when you know you'll be in the field I don't think a locker will help that much when you're pulling
maybe some more aggressive tires and a locker might help but it don't hurt anything to have the fronts locked in all the time as long as the tcase is in 2wd
Old 02-22-2015, 03:58 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
Everyone has determined that a Detroit Truetrac is the best for towing.
The others be it lockers or limited-slip will lock when turning because is senses differences in tire speed. With a heavy load this action puts things in a TERRIBLE bind!
The Truetrac will not bind while still delivering power to both wheels.
http://www.summitracing.com/parts/dtl-915a550/overview/
http://www.eaton.com/Eaton/ProductsS...trac/index.htm
Old 02-22-2015, 04:02 PM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
This.....plan ahead is the CHEAPEST solution.
Old 02-22-2015, 04:06 PM
rla2005's Avatar
rla2005
rla2005 is offline
While I agree a Truetrac is an awesome limited slip a factory trac-loc would work in your scenario just fine IMHO. Find one in a JY or online then rebuild the clutches. Restack them to make it tighter. Easy low cost solution. This is option two to my post above.
Old 02-22-2015, 04:12 PM
MI02SVT
MI02SVT is offline
Detroit Truetrac
Detroit lockers will only lock when power is applied if you coast around a corner it will be unlocked you will hear clicking tho
Old 02-22-2015, 04:19 PM
87thhunter
With the Detroit truetrac do I use my existing ring and pinion??? I'll do a lot more research on it for sure either way though
Old 02-22-2015, 04:22 PM
eakermeld's Avatar
eakermeld
You are correct. I should have said "turning under power".
Here are a couple of past discussions on this topic.
https://www.ford-trucks.com/forums/9...-truetrac.html
https://www.ford-trucks.com/forums/1...-truetrac.html
Old 02-22-2015, 04:25 PM
eakermeld's Avatar
eakermeld
Yes you do. Would be a good time for new seals and bearings, too.
The ring and pinion needs to be set up by someone that knows what they are doing or it will howl like a Banshee! If you have never done one, find a gear shop and let them do it. If you have done any then you know what I'm talking about!
Old 02-22-2015, 04:30 PM
87thhunter
Wouldn't it be nice if it was a simple in and out swap....... And no howling
Old 02-22-2015, 04:36 PM
eakermeld's Avatar
eakermeld
What I do is pick up a tight JY axle assy with the gear ratio I want, clean it up, new brakes and lines, replace the stuff that I can, send it out for the stuff that I can't, paint it, and swap it in the truck as an assembly. That costs a few more bucks to do that, but you will probably never need to touch it again as long as you have the truck.
Old 02-22-2015, 04:47 PM
87thhunter
Sad thing is i did a frame up restore on the truck - already had this one one and installed everything new, painted it ect. - now i did rebuild the axle but it has been cleaned and painted
Old 02-22-2015, 06:01 PM
rla2005's Avatar
rla2005
rla2005 is offline
You can replace the factory open carrier with a factory Trac-loc or spend more money on True-trac as outlined above.
If you have the luxury of time then you can rebuild what you have.
Old 02-22-2015, 08:31 PM
87thhunter
I'll call my local jy they give me a lot of free parts or really good deals, due to where I work - have a deal between business and they pass it onto me!!!
But I'll look and see what people have so all I need then is a limited slip out of another axle???? Everything else should be the same???
Old 02-22-2015, 08:40 PM
eakermeld's Avatar
eakermeld
If you are going to use your gears, then yes. This axle was used for many years. They changed the pinion length in '93, but if you are using your gears that won't matter.
Quick Reply: Adding Posi/limited slip 95 f250
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
