Put my truck on the computer today and it won't complete the test kept giving code p1000 the shop tried 4 times then tried to get the computer to do self dianostic no go anyone else run into this? Do I need a new computer?
P1000 is not really a trouble code. When you clear the PCM, it sets a P1000 code until it has gone throught a couple of drive cycles. If you don't have any other codes, then nothing is wrong and you don't need a new computer (PCM)
[updated:LAST EDITED ON 02-Sep-02 AT 11:52 AM (EST)]Thanks for the help cleared the codes then it threw these codes at me it seems thet my o2 sensors are shot p0135 p0141 p0151 p0155 p0161 p1132 p1152 p1000 p0460 that is the order that they came up on the reader. what is the Fuel Level Sensor Circuit Malfunction my guage works fine.
Thanks
Hey there. Wow! Has your truck had an engine change before all this? Are all the sensors pluged in? You might have a bad set of o2 sensors, but given the codes for the heater circuit you either have some wirieing problems or a bad computer. P0135 02 sensor heater circuit malfunction. B1 SEN1. P0141 02 sensor B1 SEN-2 heater malfunction. P0151 O2 SENSOR B2 SENSOR1 MALFUNCTION. P0155 02 sensor b2 sensor 1 heater malfunction. P0161 02 sensor Heater circuit malfunction B2 Sensor 2. P1152 Lack of heated 02 sensor, B2 sensor 1 showing rich.
