2000 f-150 xlt ABS Light came on
ABS Sensors
Does you F150 have 4 wheel ABS or just the rear?
If just rear check then check the sensor located in the Diff.
If it has 4 wheel ABS then I would check the front sensors first. They may have rotted away as both of mine have done. Not too bad to replace, but be sure to get a longer bolt/screw to hold the sensor onto the back of the steering knuckle. OEM sensors had a thin metal flange where the replacement had a thick plastic mount and the original bolt would not even touch the knuckle. Mine were a self tapping metric bolt.
Buy from Ford or Rock Auto.
Originally Posted by jfcpjc
Is It the ABS light or the Brake light? Asking because my brake light comes on about once a week. To turn it off I have to release the parking brake. ( I hit the parking brake pedal when entering by accident)
KrisDozark
07-10-2004 04:03 PM
