Draining Torque Converter?
Old Jun 24, 2007 | 02:58 PM
BDalton's Avatar
BDalton
I want to drain/fill the tranny to include the torque converter. I searched and found that on pre '01 models (mine is an '00) the converter can be drained. My question is how do I get the drain plug to the bottom so I can drain the converter? Can it be rotated by hand? Also, it should take 16-18 qts correct? Thanks for the help.
Old Jun 24, 2007 | 03:01 PM
ron's power stroke's Avatar
ron's power stroke
socket on the big nut on the front bottom pully..18 qt's
Old Jun 24, 2007 | 04:21 PM
BDalton's Avatar
BDalton
Thanks. Tranny in neutral or does it matter?
Old Jun 24, 2007 | 05:15 PM
SpringerPop's Avatar
SpringerPop
In park would be the safest.
Otherwise, doesn't matter.
Pop
Old Jun 26, 2007 | 02:05 AM
ramsmoker's Avatar
ramsmoker
Talking drain
My truck is a 01 and I just drilled a 5'16 hole and tapped for 1/4NPT.
Old Jun 26, 2007 | 08:57 AM
vettdvr's Avatar
vettdvr
Great idea but with my luck the drill would slip hit the fins bend them and the day would be over.
Old Jun 26, 2007 | 05:01 PM
ramsmoker's Avatar
ramsmoker
Talking drain
Its not that bad, you'll be gett'n peed on before you go thru. You could use a small pilot drill first I guess. I've beed drink'n oil all my life, you get used to after a while.
Old Jun 26, 2007 | 07:21 PM
SpringerPop
How much does anyone estimate that new plug puts the TC out of balance?
Think it might affect the front bushing's lifespan?
Pop
Old Jun 26, 2007 | 07:51 PM
vettdvr's Avatar
vettdvr
Pop
Probably not enough for anyone to notice. But if really concerned, you could put a second one 180 degrees opposite. That would make it easier next time to line up.
Old Jun 26, 2007 | 08:41 PM
Tenn01PSD350's Avatar
Tenn01PSD350
That's it. Shazam. I have often thought about Pop's ? and whether the ones with stock plugs were balanced. That solution was so simple I couldn't even come up with it. Damn. Good stuff.
Old Jun 26, 2007 | 09:00 PM
sgrol's Avatar
sgrol
Would never drill and install a plug in TC before reading this. What a great idea and easy solution to out of balance problem. And yes, it would be out of balance whether you noticed it or not.
Old Jun 27, 2007 | 06:25 AM
vettdvr's Avatar
vettdvr
Photos of exactly where the plug was drilled would be helpful.
Old Jun 27, 2007 | 07:25 AM
15 and 92 Dad's Avatar
15 and 92 Dad
Why not just use the method posted earler on chaging your tranny fluid by disconnecting the most aft line on your transmision (return from cooler) put a clear hose on the line, start truck, You get the idea! Its posted!
Rich
Old Jun 28, 2007 | 10:02 AM
Casey's Avatar
Casey
Originally Posted by 15 and 92 Dad
Its posted!
Here it is:
https://www.ford-trucks.com/article/...nsmission.html
05ExcursionLTD
Jun 19, 2009 07:15 AM
Mustangoutcast
Jan 15, 2008 12:06 PM
redneckboy
Feb 19, 2007 10:17 PM
eandaauto
Jun 11, 2004 11:01 PM
MJW
Mar 10, 2004 07:15 AM
