head gasket bad ??
Old Jun 24, 2007 | 11:24 AM
jstone400m's Avatar
jstone400m
head gasket bad ??
Hi, I'm new to the diesel forums here.
my 99 f250 with 95k. keeps pushing coolant out the burp tank. i've replaced the thermostat and the water pump. the coolant looks good and no coolant in the oil.
when it happens the temp gage pegs hot and the upper radiator hose is cold then i crack the radiator cap and it get lots of air.
Old Jun 24, 2007 | 12:06 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Any mods done to the engine? Seems unlikely that a stock motor with only 95K miles would pop an HG, but it would probably be worth your time to have the compression checked.....especially if it's been overheated a number of times.
Old Jun 24, 2007 | 12:26 PM
rbaker6336's Avatar
rbaker6336
[QUOTE=jstone400m]
when it happens the temp gage pegs hot and the upper radiator hose is cold QUOTE]
sond like not circulating
Old Jun 24, 2007 | 12:28 PM
bandlgeorge's Avatar
bandlgeorge
could that be a stuck thermostat? With the upper radiator return hose cold, that would tell me that the hot coolant is not getting circulated. Thermostat should be a cheap and easy fix, plus you can always check to see how the old thermostat works on the kitchen stive, unless it's obviously stuck partially open. Gone through my fair share of thermostat's (not on my PSD, an old subaru) Good luck! I would think if you had a bad head gasket you would start seeing water in the oil. Had that happen twice as well (Subaru again) hmmmmmmm . . . Maybe that boxer engine isn't so great after all?
Old Jun 24, 2007 | 12:39 PM
rbaker6336's Avatar
rbaker6336
take thermostat out and try it is blockage some where ,almost sure
a long shot once had top rediator hose separate and blocked flow
Old Jun 24, 2007 | 01:18 PM
gunnertom's Avatar
gunnertom
It also coud be a bad hose,At idle everything looks good but when the water starts to flow faster it sucks the hose in an closes off circulation.
Old Jun 24, 2007 | 01:24 PM
rbaker6336's Avatar
rbaker6336
Originally Posted by gunnertom
It also coud be a bad hose,.
yes actually could be either hose I stated top but lower could also do it
Old Jun 24, 2007 | 02:31 PM
jstone400m's Avatar
jstone400m
I have no mods bone stock. I" check the hoses and take the thermostat out agin and try it some more... thanks..
Old Jun 24, 2007 | 06:12 PM
Uzumati's Avatar
Uzumati
When you replaced the thermostat you did get the long stem version didn't you.
The short stem one that most part houses carry will not seal off the bypass when it opens and can lead to the rear of the block overheating.
Old Jun 24, 2007 | 10:47 PM
jstone400m's Avatar
jstone400m
well it has turn for the wost, i replaced the lower radiator, start up the truck idling it start blowing smoke and making all kinds of noise. and now the water has a lot of oil in it .........
Northriver
Dec 27, 2009 07:04 PM
virgojeep
Dec 1, 2009 08:27 PM
mfriesen
1983 - 2012 Ranger & B-Series
Mar 19, 2006 07:34 AM
maticuno
1997 - 2003 F150
May 28, 2005 11:55 PM
JoeF150
Oct 30, 2002 01:15 AM
