Sponsored by: Auxito
Coolant Flush
Old May 21, 2005 | 12:11 PM
maticuno's Avatar
maticuno
Coolant Flush
I know the coolant flush procedure...but I am used to having a radiator cap to poor fluids back into. Either this truck does not have a radiator cap, or it is buried under that plastic cover over the radiator. Basically all I'm asking is do I need to find the radiator cap? Or do I have to slowly add fluid through the expansion tank?
Old May 21, 2005 | 12:59 PM
Aftrmidnite's Avatar
Aftrmidnite
One of the most frustrating cooling changes I ever did. I have a 4.6, there is no block drain plug on the right side, only one on the left. The engine holds almost 3 quarts of coolant when the radiator and block plug are open. Kept rinsing and rinsing. It helped to use the discharge on a wet vac to blow the coolant out, by blowing thru the reservoir and heater hose. Make sure you plug the one you are not blowing thru to keep anti-freeze off the paint. I'd do the final rinse with distilled or RO water. Drain and measure full strenght coolant, at half the system capacity to the pressurized reservoir. Start engine and top off with distilled or RO water.
Old May 23, 2005 | 12:19 AM
maticuno's Avatar
maticuno
Thanks for the info. Anyone want to add anything else? Or was that it?
Old May 28, 2005 | 10:41 PM
texasranger185's Avatar
texasranger185
could you say where that plug is or what it looks like. I'm banging my had against the wall on this one too. I have a Triton 5.4 2001 in an expedition.
Old May 28, 2005 | 10:56 PM
Aftrmidnite
On my 4.6L you crawl under the truck from behind the left front wheel. The plug is right next to the frost plug, it's six sided and brass colored, and is in fact soft steel. You can see the treads behind the hex, and they have brunt orange colored pipe dope on them (Gasolia Dope?). Thats how you can tell it from a bolt. On the 4.6L there is a plug right behind the altenator, the plug below looks the same.
Old May 28, 2005 | 10:59 PM
fordguy21's Avatar
fordguy21
I have a 97 f-150 4.2L and their is no raditor cap on the raditor itself, but you use the overflow tank as your access when filling up the raditor with coolent, and you fill it up to the min line on the tank.
Old May 28, 2005 | 11:06 PM
texasranger185
Left front wheel meaning the drivers side?
Old May 28, 2005 | 11:17 PM
Aftrmidnite
Yes, the extension on my rachet handle was up against the suspension. I believe the 4.6 and 5.4 are the same, just one is bigger. Its really easy to get the coolant back in the system and filled. Just hard to get it all out.
Old May 28, 2005 | 11:27 PM
Aftrmidnite
my extension was up against the Lower Control arm, there's a place were it has a sharp curve on it as it gets bigger. The extension was against that place and pointed straight up and slightly forward and center. The plug was17mm or 11/16" I used a 15" 1/2" extension and a 6 point deep well socket. That gave me just enough room to swing the rachet handle around, and clear everything.
Old May 28, 2005 | 11:28 PM
texasranger185
thats a big 10-4 on trying to get it all out! I think I found what your talking about. But what I'm thinking is the drain plug is the type of hex that I have to use a allen wrench on? I can see the threads like you were saying though. I'm currently improvising on a tool situation. Don't have enough leverage with my allen wrench.
Old May 28, 2005 | 11:31 PM
Aftrmidnite
Mine took a socket, it was really tight with the Gasolia dope so be careful you don't strip it.
Old May 28, 2005 | 11:38 PM
texasranger185
I flushed the hell out the system. All I'm concerned about at all is that whatever water I don't get out is tap water and has calcium in it. I'm about to just go up to the store and buy some distilled water and flush the systen once or twice with that and forget about this dam drain plug. I don't think it will bew that big of a deal if a have a pint of hard water left in the system that hold 27 qaurts. But then again, what if if does clog something up.
Old May 28, 2005 | 11:55 PM
Aftrmidnite
I doubt it will clog anything, the reason you use distilled or RO is to get the maximum life out of the coolant. Do you have a plug behind the Alt? If so it is most likely the same as the plug below.
hobbymanlp
1983 - 2012 Ranger & B-Series
Feb 19, 2011 01:07 PM
tom302
Sep 10, 2010 08:49 AM
idahodisco
Apr 18, 2010 10:41 PM
Blue Jeff
Dec 30, 2004 05:18 PM
01' Super Crew
1997 - 2003 F150
Mar 6, 2003 09:26 PM
