manual trans and pushbutton 4x4
Old Jun 23, 2007 | 06:34 PM
vols_fan22's Avatar
vols_fan22
How common is it to find a f150 or f250 with the v8, manual transmission, and pushbutton 4x4? Or is this very rare?
Old Jun 23, 2007 | 08:53 PM
lostin90s's Avatar
lostin90s
Any manual trans with V8 after 93 is a rarity in the F150 . But more with 302 that 351.
As for push button in a manual . Most loaded Xlt that had the manual had the auto xsfer case in the trucks I have been looking at .
Old Jun 23, 2007 | 09:19 PM
brown 4x4's Avatar
brown 4x4
How common? Probably impossible. Push button 4x4 was only available in the F-150, with a V8 and automatic transmission. The 94, 95, and 96 brochures state this. I can't find any proof in the 91, 92, or 93 brochures, but have never personally seen one that isn't V8/auto. Maybe a few did exist in these first years of it.
Old Jun 23, 2007 | 09:48 PM
jas88's Avatar
jas88
Yeah, my recollection is that pushbutton 4x4 was only available with auto trans.
Old Jun 25, 2007 | 02:19 PM
vols_fan22's Avatar
vols_fan22
ok thanks i didnt think that it was common but is it possible to put a manual trans. in a truck that has auto trans and pushbutton 4x4?
Old Jun 25, 2007 | 02:29 PM
jas88's Avatar
jas88
The ECU that controls the 4x4 will demand that the trans be in park or neutral before it will allow you to do 4x4 low, so you will need to fool it into thinking that is the case since you will be removing the MLPS that tells it that info.
But most folks don't like the maybe-it-will-and-maybe-it-won't of the pushbutton setup and replace them with the manual xfer case anyway.
Old Jun 25, 2007 | 02:30 PM
jas88's Avatar
jas88
Well, maybe not "most", but it is a common swap. I'm gonna do it on my SAE Bronco as soon as I locate the proper xfer case for cheap.
Old Jun 25, 2007 | 11:30 PM
alxsnmr's Avatar
alxsnmr
Actually all you have to have is a grounded wire to get the auto transfer to shift into low. The transfer case is a shift on the fly model and was set up with auto transmissions. If you are going manual transmission why would you want a push button transfer case?
Old Jun 26, 2007 | 10:29 AM
vols_fan22's Avatar
vols_fan22
ok thanks, i would like to have the manual shift transfer case but with a 3" body lift the lever isnt long enough for it to go into 2hi but it will gointo 4x4 hi and low easy, but i can get an extended linkage for the manual trans. but im not finding any extended linkages for the transfer case.. but thanks for all yalls help!
Old Jun 26, 2007 | 11:04 AM
Bruce R Leech's Avatar
Bruce R Leech
you can extened, it it is easy
Old Jun 26, 2007 | 04:38 PM
vols_fan22's Avatar
vols_fan22
im not tryn to be and idiot but what would be the best way to extend it?
Old Jun 26, 2007 | 04:50 PM
lostin90s's Avatar
lostin90s
My bad!!! most of the trucks I look at are for parts. So the manual one I've seen they must have put switch/bezel for electric in dash or put manual trans in and auto truck . Thanks for the info .
marvlalone
Oct 3, 2014 08:09 AM
truckintony
20
Mar 24, 2011 04:04 AM
baw289
1978 - 1996 Big Bronco
Nov 23, 2003 05:16 PM
WhëëlMå1
Nov 17, 2002 04:00 PM
fiend
Offroad & 4x4
36
Nov 15, 2002 08:37 AM
