My pushbutton 4X4 went out again, gave a few taps with the hammer, nothing happened. Everytime I need the 4X4 it doesn't work, so I want to switch to a manual engaugement. Is there a conversion kit out there that lets me use my existing transfer case? or do I need to pick up a new one with the linkage? If I do need a new transfer, which one do I need to get?
that tech write-up will help. the t-case that you are going to want is BW 1356 thats made for a manual shift setup, then you need the shifter made for whatever tranny you have.
Steves right, give it a chance to fix yours i did and its not that complicated(good info site) and i ended up with 0 dollars invested, just time ne
ed help we will be glad to assist you . ---For parts a salvage yard in cheap TR
