94 F350 bed replacement?
Old Jun 21, 2007 | 09:26 PM
ArcadeMike's Avatar
ArcadeMike
Hey everyone. I have a 1994 f350 dually with a reading utlilty box on the back. Is it possable to put a regular dually bed back on the truck or am I stuck with this thing? The reading box is starting to rust away.
Thanks,
Mike
Old Jun 21, 2007 | 09:44 PM
FarmForward's Avatar
FarmForward
You should be able to find a replacement bed for the truck. I'm guessing that the utility bed uses the same mounting points as a factory bed does. Check the local boneyards for one. You'll have to find some dually fenders to cover the outsides, but they can be had, as well. A good starting place to find them would be LMC Truck.
You might also consider a flatbed for the truck. Just depends on your wants and needs.
Old Jun 21, 2007 | 10:12 PM
Bruce R Leech's Avatar
Bruce R Leech
yes if you find one it will fit
Old Jun 22, 2007 | 08:52 AM
lostin90s's Avatar
lostin90s
You can use any bed will bolt up . (may have to grind off mount or 2 for the READING . You can get a single wheel bed and put the fenders on if can't find the condition you want. You should have no problem getting a bed in SC that is where I go to get body parts .
If you were 1 month earlier local guy pulled one out of garage he removed in 95. Was like new $1200 . Guy bought it and put it on a 99 Dodge ??
Good luck on search
Old Jun 22, 2007 | 09:55 AM
92F150Flare's Avatar
92F150Flare
Welcome to FTE ArcadeMike........Nice to see more SC'ers
.Bakers Truck Parts up in Greenville might have what you are looking for.....located at 1200 White Horse Rd.......phone is 864-277-9479. They had a tailgate for my Flareside........hard to find.
Try the SC forum too......someone there might have more ideas
Good Luck
Bob
Old Jun 26, 2007 | 06:35 PM
ArcadeMike's Avatar
ArcadeMike
Thanks! I will give them a call
Mike
fordrocks96
Nov 10, 2017 11:14 AM
the beast 1
May 1, 2015 07:54 PM
Dean06919
Mar 29, 2015 08:12 PM
jerry65
16
Feb 1, 2015 08:09 AM
CortStrasser
Jan 8, 2015 07:05 AM
