Driver's side power window motor
Old Jun 3, 2018 | 12:24 PM
fatswany's Avatar
fatswany
OK, I tried slamming the door thing, still no go. So, the motor can work in the "up" direction, and not in the "down"?
Looking like the is going to be my solution, although in the interim of getting a motor, I might try to pull it and see if I can go the cleaning route.
Old Jun 3, 2018 | 04:50 PM
fatswany's Avatar
fatswany
Well.......new motor....same problem. I am baffled! 12.4 v. to the motor harness, in both UP and DOWN switch positions, swapped out relays with another relay that was working passenger side, motor runs fine on the UP mode, nothing on down. Freewheeling, not installed. I can move the glass by hand, so not an issue.WTH is going on??? HELP!
Old Jun 8, 2018 | 08:55 PM
fatswany's Avatar
fatswany
Well........crickets.........nothing..........anyt hing??????
Old Jun 12, 2018 | 08:50 AM
2trux's Avatar
2trux
Have you tried the motor plugged into the harness but not attached to the regulator to see if it spins both directions?
Krazyhorse93
Oct 14, 2016 02:00 PM
Kendal
May 10, 2016 12:50 PM
cypressdelight
Apr 24, 2016 01:55 PM
teamlx88
Feb 2, 2014 03:34 PM
teerex
Nov 11, 2013 08:30 PM
