2004 Expy Master power window switch
Old Apr 21, 2016 | 12:47 PM
cypressdelight's Avatar
cypressdelight
Unhappy 2004 Expy Master power window switch
I just replaced the driver's side window regulator with new motor and also a new master window switch. When I press down the window goes up - press up the window goes down. I've tried the switch deinitializing and initializing instructions from the ford manual without success. Can anyone tell me what I'm doing wrong? Thanks
Old Apr 24, 2016 | 12:54 PM
alloro's Avatar
alloro
You're doing nothing wrong, the people that assembled the motor installed it 180 degrees off. You can exchange the motor and try again, attempt to turn the end of the motor yourself, or, you can remove the 2 wires from the electrical connector and reinstall them in the opposite locations.
Old Apr 24, 2016 | 01:55 PM
cypressdelight
Smile 2004 Expy Master power window switch
Thanks for the reply. After ordering and receiving a second switch (from a different vendor) and having the identical problem I took your last suggestion to heart and reversed the wires on electrical connector. The window now operates perfectly including the Auto function.
2.7EcoBoost
2015 - 2020 F150
Aug 5, 2019 11:12 AM
mike L
Sep 23, 2013 09:42 AM
psheridan
2004 - 2008 F150
Jun 24, 2013 06:14 PM
SuperDutyScaler
Aug 8, 2012 11:03 AM
Taboo
Jul 24, 2007 12:24 PM
