Sponsored by: Real Truck
2005 Upfitter
Old Jun 15, 2007 | 02:36 PM
teemeup's Avatar
teemeup
Thumbs up 2005 Upfitter
Can anyone help locate the upfitter connection on 2005 F250. I am looking add rear lighting and want to us upfitter # 3. I believe the connection block is located the behind the glove box. Any assistance would be grateful.
Thanks Lon
Old Jun 15, 2007 | 02:52 PM
deercreek1's Avatar
deercreek1
Upfitter switches
Good Luck - I eventually gave up. Nothingin the Owners Manual that I could find.
Old Jun 15, 2007 | 03:03 PM
rwilimo's Avatar
rwilimo
This link contains all the information that you will need. https://www.ford-trucks.com/forums/4...-switches.html
Old Jun 15, 2007 | 04:29 PM
teemeup's Avatar
teemeup
Rwilimo, Thanks for the link. They were right behind the fuse block. Thanks again.
One more question if I may, What is the advantage of high idling? Thanks
Old Jun 15, 2007 | 06:27 PM
rwilimo's Avatar
rwilimo
On the bus's I work on, we use high idle for higher alternator output and A/C when parked.
Old Jun 15, 2007 | 09:46 PM
stewcon's Avatar
stewcon
One more question if I may, What is the advantage of high idling? Thanks[/QUOTE]
Also to prevent wet stacking in cold weather.
Old Jun 15, 2007 | 11:01 PM
6L PWR's Avatar
6L PWR
From what I understand, someone correct me if I misunderstand, the 6.0 runs a bit cold at idle. Wet stacking is what happens because of this. The fuel starts to puddle in the cylinders and leaks down into the crankcase. By high idleing, you keep it warm enough to burn the fuel and prevent this.
Old Jun 16, 2007 | 05:37 AM
teemeup's Avatar
teemeup
Thanks for the input.
Old Jun 16, 2007 | 05:45 AM
ford390gashog's Avatar
ford390gashog
Also under serious wet stacking the engine can hydrolock.
icee
Jul 21, 2013 01:00 PM
zitman11
Mar 21, 2010 03:16 PM
QDWilliams
Electrical Systems/Wiring
Jan 1, 2009 06:02 PM
FSeybert
Dec 19, 2007 08:26 PM
FSeybert
Feb 14, 2005 05:26 PM
