1978 - 1996 Big Bronco
need quick response guys
Old Jun 19, 2007 | 01:08 PM
  #46
94broncoxl's Avatar
94broncoxl
Holy crap your right, I just checked out Standard Motor Products site, they have an on-line parts look-up, and when you go to VSS for 1994 Bronco all they show is the older gear driven styles. These must all be for AOD(E) transmissions. You have to go to Rear ABS sensor for the one in the differential, but as we know it serves both purposes.
Old Jun 19, 2007 | 01:12 PM
  #47
Kemicalburns's Avatar
Kemicalburns
crazy huh. all this time i thought the vss was the part in the rear diff. i understand that the rear abs does double duty just major confused at name of part originally.
Old Jun 23, 2007 | 12:26 PM
  #48
Kemicalburns
what port do i plug into for abs code. there is no self test in for abs test port
do i need to push the brake also for that to work??
the 94 would be a 3 code correct not 2.doing the KOER next.
KOEO
116
115
117
114
111
111
KOER gave me a 536
Brake On/Off circuit failure / switch not actuated during KOER test
what would cause this??
Old Jun 23, 2007 | 05:55 PM
  #49
b4hntn's Avatar
b4hntn
KOEO
116 Engine coolant temp higher or lower than expected.
115 My book does not show 115
117 Engine coolant temp below minimum voltage.
114 Air charge temperature higher or lower than expected voltage.
111 System pass
111 System pass
KOER can only be done after you get clear codes 111 in KOEO
KOER inclues some tests where your turn the wheel, step on the brake and turn OD on and off once.
Have you checked the connections to the engine coolant temp sensor? It is on driver side, midway along the intake maniford and has two wires running to it.
Engine must be warmed up to pull codes.
Old Jun 24, 2007 | 07:05 PM
  #50
Kemicalburns
had autoparts store pull codes. all that came up were tps and map sensor.
ive checked all the fuses. my next thought is perhaps the abs module or psom. problem is i can not locate the psom.
Old Jul 2, 2007 | 09:08 AM
  #51
Kemicalburns
I went to les schwabs to have a few things checked out and while it was there to pull abs codes. they were unable to do so. now either they flat out didnt do it or something else is wrong to cause no codes from the abs code port.
pilot1006
Dec 24, 2014 11:23 PM
getsch58
1983 - 2012 Ranger & B-Series
Nov 29, 2008 05:36 PM
ken selvy
Aug 30, 2006 03:07 PM
