Kem, I have to get a stool to reach the dip stick. The A/C evaporator box has insulating foil blanket which may flop over the dipstick which is low between the A/C box and engine. Maybe someone esle can help with vss.
because if you go to the parts store. the Vehicle speed sensor is a totally different part then what is bolted to the top of the rear diff which is called the rear abs sensor.
now that rear abs sensor talks to other things and im sure senses vehicle speed via a pulse but it not truely called that part
