Tekonsha all NEW P3 Brake controller
I've been tossing around buying a brake controller for my SD (see sig)...and noticed that Tekonsha has an ALL new controller called the P3.
http://www.tekonsha.com/p3.html
Has anyone installed and towed with it? Any opinions .vs the Prodigy?
Thanks,
biz
Thanks,
biz
biz4two,
I have not used one as i have the FMC factory unit, i have used the Prodigy with great success in my other vehicles.
The new "P3" appears to be an updated Prodigy with more features and diagnostics. This looks like the Prodigy on steroids. IMO if i was in the market for a new controller i think i would jump all over the P3.
The P=Prodigy 3=Marketing. Good upgrade of a Prodigy, internally they are the same. Instead of digital read out they came up with a LCD monitor, put a new bracket on it, and put an on/off switch to the diagnostic check to allow older electric/hydraulic actuators to work (mainly Carlisle pre Feb 07').
Well thanks for the responses.
I was doing an internet search on the P3 in relation to cost. I found that it ranges from $133 - $174...pretty reasonable I thought. Then I find it for $127.00...and YES the $20 rebate is in the box. Plus FREE shipping.
So...for $107.00 I just ordered a P3! The only thing...is it's on backorder and will not ship until June 14th, but NO worries here...not in a rush.
Thanks again for the replies...
biz
biz
Nice Install
***UPDATE***
Installed my new P3 brake controller and all went smooth! I installed in the typical location for the SD trucks: on the dash under the storage hole. I did purchase the plug-in-play wire adapter...so no issues with the wiring.
I am able to "play" with the LCD display colors (good color options...IMO) and changed to the green...so it matches my SD. Was able to get a voltage reading of my battery...but that was about it...so far.
Unfortunately...I have not towed with it yet. My TT is at the RV shop for warranty work. They've had it now 2 wks...so itching to get it back and test the P3.
When I tow...I will have another Update.
biz
biz
Sorry to bring the dead back up, but has anybody installed one of the P3s on a 2003 6.0L 350? Tekonsha is saying that I have to have Ford reflash the ECU to recognize the trailer, Ford tells me they have no updates for the ECU to flash. Need help asap please! I have to tow in three days. Thanks!
You should have no issues with a 2003 SD with a 6.0L PSD. Good luck...
biz
Just because someone at the factory says something, doesn't necessarily mean it is correct. I haven't installed this particular unit in your model truck, but why would it be only the P3 that would require a reflash? I haven't read a think from a single manufacturer that says anything about reflashing including the installation instructions I have been sorting through. Does it say that in the instructions that come with the controller? If it does, in my opinion, that is a heck of a design flaw. Who on earth would design a controller that required the consumer to take their truck into a dealer after installation and what RV dealers would install it. It just sounds nuts!
My two cents worth,
Steve
Medic 66
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
26
10-30-2016 07:28 PM
M@ts
06-14-2015 06:46 AM
SoCalAngler
24
05-16-2015 10:32 AM
RÖENTGEEP
04-21-2008 01:49 PM
2000, 250, albuquerque, box, brake, break, control, controller, controllers, craigslist, ebay, f150, ford, install, nm, p3, prodigy, tekonsha, trailer
